Cabinet Scraper
Cabinet Scraper
Cabinet Scraper
Howard Metz
>I�ve recently discovered the joy of scraping using a scraper in the Vertis scraper holder. What is the difference between using the Vertis scraper holder and a cabinet scraper such as the Stanley # 80 as far as finish or rate of removal of material?
Thanks
Howard
Re: Cabinet Scraper
Re: Cabinet Scraper
Matt Williams Marysville, WA
>It is easier to get a level, flat finish with the larger base. Obviously a 112 provides more than an 80 :)
Re: Cabinet Scraper
Re: Cabinet Scraper
>You can put a lot more pressure on the scraper with the 80, 81, 12, and 112 (And several others, along with the Lee Valley and Lie-Nielson) than you can with just a card holder or a card by itself. A good freshly sharpened scraper in a nice scraper plane will give big curly shavings compared to small shavings when hand held. Making sure the burr is at the right angle if you use a burr in a scraper plane is somewhat critical.
Re: Cabinet Scraper
Re: Cabinet Scraper
David Hay @ Denver
>On a related note, I received an older #80 scraper for Christmas. Can anyone point me to a good site on how to tune, set up and use one of these things?
Thanks!
David
Re: Cabinet Scraper
there is a concise page at... *LINK*
John Truxell-Svenson (jvs)
>...Ralph Brendler's site at the link below. You can also do a message search here or at Old Tools for [scraper sharpening #80] for a few dozen more posts and perspectives. If you have questions after that, just ask away. The only thing that I have to add is that the usable edge on an aftermarket blade from Ron Hock will last a lot longer than anything you can do with a stock Stanley blade, at least of the more recent vintages. If you have an older one, it might be just fine.
/jvs
http://www.brendlers.net/oldtools/scraping/scraper.htm
