Stanley 12 scraper blade
Sanford Levy
>Hi people. I was wondering what would work as a replacement blade for an old Stanley 12 scraper plane. Someone offered me one without a blade and I do not know much about them other than I would like one! Thanks. Sanford
Re: Stanley 12 scraper blade
Frank Mutchler
>Sanford, there's a thread on this subject that you can find via the search engine. I'm using low carbon ground flat stock by Starrett purchased from a local tool supplier. 1/8" is too thick for my #12 1/2 but 3/32" works.
I get a 3" x 24" piece for $21.00. It makes four 6" blades..about $5.25 apiece. If you would like a cheaper alternative, many folks here recommend using old saw blades.
>I don't have one to compare with, but aren't the 12 and 112 scraper blades the same dimension? In which case you can get a Lie-Nielsen replacement.
Roy: Vista CA
>The blades to the 12 and 112 are the same. 2 7/8 " wide by 5 7/8" long
>Mark is correct. I use a LN "Stanley Replacement" blade in my #112, which will be the same for a #12. Awesome blade!
Roy: Vista CA
>Thickness is the same also.
Stanley 12 scraper blade followup
Sanford Levy
>Thanks! I will check out the LN replacement. But I wonder about Frank's comment about making his own from low carbon stock. I know little about steel, except that it is not wood! If I wanted to make my own, do I look for low carbon steel? Somehow I thought tool steel was not low carbon. Is the steel in saws low carbon? Any suggestions as to where I can read about such things? Hm. . . maybe their is a thread I should search for. Sanford.
Sanford Levy
>Oops! I found the earlier thread with a fair amount of information. Sorry, I usually do searches before asking. Must have been tired and lazy! Sanford
