New Bench Problem...(long)
Christopher Fitch @ Memphis
>Hey everyone,
I have been working on a new bench based off the plans from Christopher Schwarz from the Dec. 2003 issue of Pop. Woodworking.
So far things have gone ok...
Some mistakes and some changes but all in all it's coming along (finally).
I did the top first and then I just completed the base this afternoon.
I decided to see how it sat on the base and after moving it over, I noticed a problem. One corner of the top was sitting above one leg by about 3/32" to 1/4" or so. I had already checked the top and though it was slightly not flat, it was at most off 1/32" which I planned on sanding flat (it's a laminated plywood top).
At first I though maybe the top had a twist, but after checking with winding sticks, I did not see any problems. I measured the legs again and they all checked out great. I measured from the floor to the top of each leg and I noticed some variance, say about 1/16" but nothing that would correspond to the problem leg. I moved the top back on to my old bench and got the idea to flip the base upside down and rest the legs on my new top. I noticed that one leg was about 1/8" off and I marked it.
After that I thought I had figured it out...but I ran into a snag. I put the base back on the floor and put the top on it. I moved the bench over about 2-3 feet and I noticed that, all of a sudden, my twist was gone. I moved it back to the original spot, and it was there again. I moved it further, and not only did I have twist, but one leg was not sitting on the floor. So now I'm in a quandry. I knew my floor was not flat, but I did not expect it to throw off the bench that much.
My initial thought is that my flip-the-base-upside-down-on-the-top is the correct indicator of the problem but I'm not sure because the legs are definitely the same length within over 1/128" or less. So adding 1/8" to one leg, as a solution, seems wrong.
One other note: with the top on the base, I checked how level the bench was and it was off. But if I push the top down to meet the low leg, the top is level.
Any suggestions on how to proceed?
Thanks in advance!
Christopher
