OT Painting Problem
OT Painting Problem
Kneale Brownson
OT Painting Problem
kneale brownson
I've been having a pint of paint tinted to match the color on walls in our house that we are going to sell. I want the paint to cover where there will be holes from hanging stuff on the walls.
I have been back repeatedly to get a bit more tint added until now I have a perfect color match. But the level of sheen in my paint differs from what's on the walls. So if I look at the new paint dried on the wall from one angle, it disappears completely into the wall, but change angle and it looks very obvious.
Paint store says there's no way to match the sheen. There's nothing they can add to my perfectly colored paint to make it shine a tad more.
Anybody got a solution for the sheen difference? What we started with in my sample is an egshell finish paint. Looks like what was painted on the walls may have been a satin finish.
Re: OT Painting Problem
johnv
If the new paint is a bit more shinny, you can dull it with careful buffing with 0000 steel wool.
walta
My builder wanted a large up charger for gloss and semi gloss paint for the very reason you discovered. It is next to impossible to make an undetectable touch ups without repainting the whole wall.
Walta
Kneale Brownson
New paint isn't shiny enough
kneale brownson
Matches color perfectly and disappears at some angles, but becomes very visible at other angles because the amount of shine doesn't match.
Paint base I started with was an eggshell. I'm going to start over with a that produces a little more sheen.
AZ in Colorado Springs
Can you arrange furniture or some other "obstacles" to encourage people to view from the angle where the mismatch is less obvious? (This is not meant as a joke, but a suggestion.)
Keep a couple of things in mind. You are selling the house and right now trying to make it "perfect" to avoid buyers objections and to not turn off a potential buyer. You are staring at this problem with intensity. Buyers will be looking at the whole thing and may not even notice this.
And, if they notice they may not care because they are going to repaint anyway.
Let a friend unaware of the paint issue look around and see if they pick it up.
Kneale Brownson
Satin is way more shiny than eggshell.....
kneale brownson
And looks almost as bad on the wall!!!!
Thinking about mixing a bit of each.
Kneale Brownson
Re: Satin is way more shiny than eggshell.....
kneale brownson
The darker area at the edge is the eggshell. The shiny mess is the satin. Too flat in one instance and too shiny in the other.
pecker
Whenever I have to repaint an area more than a couple square inches, I just go over the whole wall, until I reach an intersection with another wall or ceiling, or both. Usually the adjacent wall or ceiling will have a completely different angle of light hitting it and so will look completely different from the wall you are repairing. The mismatch in sheen won't be noticeable then.
Kneale Brownson
Re: Just trying for nail holes, mainly.
kneale brownson
Hate to just spackle them and leave them.
