Air Nailer Repair
Ken K
I’ve got a Porter Cable 18 ga finish nailer that needs a new piston ring. As long as I’m ordering parts, is there anything else I should replace while I have the gun apart? Complete rebuild kits are kinda pricey at $55.
Air Nailer Repair
Ken K
trigger kit
Jack Guzman from Maine
I find that the trigger piston is usually the first thing to go. They come in a kit.
+1 on trigger piston
David Yoho
I had to replace the trigger piston on my PC 16-gauge finish nailer last year. I would add one to your order and either replace it or hold on to it for later.
Re: +1 on trigger piston
KenK
Jack & David, thanks for your replies. I can't seem to find anything labeled "trigger piston" on the exploded parts diagram. They do sell a "trigger valve assembly" which I believe contains the parts numbered 201 through 207. Is that what you were referring to?
David Yoho
Ken, I guess I assumed the brad nailer trigger valve was like the finish nailer trigger valve. Looking at the parts diagram it's different. It does the same thing by passing air through to fire the mechanism but the 18-gauge gun has a group of parts where the 16-gauge has a trigger valve assembly.
As long as your gun fires when pulling the trigger, I'd say you don't need the parts. However, it might not hurt to have them on hand since some of the PC parts for their nailers are becoming not available.
Your call.
KenK
Thanks David. My experience with "extra parts just in case" is that it's like buying a guarantee that those part will never wear out ! Of course if they do it will be during the middle of a project and the needed part will be on back order.
Or NLA. Most PC parts a few years old are NLA
