Small router stuff from Lee Valley
Johanna Johanson
Hurrah! I knew that Lee Valley would eventually produce accessories for small routers. I just ordered the base plate and ring nut. I'll see if they can be used with my PorterCable set of template guides or if I need to purchase a set of Veritas template guides. It will be really nice to be able to use the small router on small items rather than the large one.
Re: Small router stuff from Lee Valley
Could you post a little more info? I went to Lee Valley and rummaged around a bit but did not find it.
jessecloud
Barry, Johanna may be talking about LV's line of accessories for their "Plane Base for Rotary Tools" which lets you use a Dremel or similar gadget as a router. I use it for inlay work - bee's knees.
https://www.leevalley.com/en-us/shop/tools/power-tool-accessories/router-accessories/73720-veritas-plunge-base-for-rotary-tools
or go to Lee Valley and search for part number 05J65.01
Mark Nowicki
These days , if you want to find something on the LeeValley's new cluster hug of a website, you have a better chance using Google instead.
For example " Veritas table for compact, (trim to you and me) routers" will bring you to their site; scroll the bottom to " related products. "
Just be careful you don't end up in their kitchenware section.
Dave's Not Here
Just a WAG but this may be what the base plate is, https://www.leevalley.com/en-us/shop/tools/power-tool-accessories/router-accessories/110560-veritas-compact-router-base-plate and this could be the nut, https://www.leevalley.com/en-us/shop/tools/power-tool-accessories/router-accessories/111059-ring-nut-for-veritas-template-guides-inserts-and-inlay-bushings
Good Stuff, thanks.
Ordered one.....
I think this will be good and especially like the ability to add the guide bushings.
Johanna Johanson
Yep - those are the items for compact routers. I just logged on again, so had not seen the question. Thanks for posting it.
Re: Ordered one.....
Johanna Johanson
Yes, Barry, that is the item I have been waiting for. Thank you, Lee Valley!
