Wedging round tenon question
My son and I are making a stool. (actually, he turned the legs probably fifteen years ago and has moved close enough to continue the project.)
The tenons on the legs are round and straight sided cylinders, not tapered. We have drilled holes in the seat that are a close match/snug. We plan to wedge the tenons. The question is which way to cut the slot?
Imagine the annual growth rings as a set of parallel lines. Do we cut the slot parallel to the and between the growth rings or perpendicular to them or does it matter?
Any help would be appreciated.
Re: Wedging round tenon question
Dick Coers
Perpendicular to the growth rings. The direction where nothing is easy to split.
I would either taper the tenons or champher the holes a bit to allow you to get more wedge into the joints.
Re: +
Larry Barrett
When you insert the leg/tenon in the stool try to orient it so that the wedge is perpendicular to growth rings in the seat so the wedging action doesn’t split the seat.
What they said.
I typically use a band saw to cut the kerf in the tenon for the wedge.
I then take a rasp or file to the kerf edges to make it easier to get the wedge into the tenon.
wedges
Philip F Duffy
Don't forget; glue on one side only of the tendons so they can move into the hole as the temp/wx dictates.
Re: wedges
Phil, I'm not sure I understood your advice there. Can you elaborate
Jim DeLaney, Austintown, Ohio
Odd guy out, here, I guess. I'd use a rasp or reamer to taper the holes in the seat from top to bottom, then, paying attention to the grain of the top, I'd wedge the leg tenons across the grain in the top. Wedging parallel to the grain will result in the top splitting.
As for the legs, others have given good advice regarding cutting the wedge slot in them.
Jack Guzman from Maine
Re: wedges
I do this when gluing wedges in a windsor chair build. Glue on both sides causes the tenon to pull away from the mortise wall if the tenon shrinks. Glue on one side only lets the wedge pull away from the tenon on one side of the split instead.
Re: wedges
Philip F Duffy
- - -what Jack said.
John McGaw
I can't weigh in on the tapering but I'd definitely make sure that the wedge was oriented based on the top's grain and not worry about the leg so much. If the tenon is in a tight-fitting mortise the chance of splitting seems rather minor but the top would be the place that any splitting would be likely. If the mortise expands with seasonal changes the top will be bearing all the pressure.
Good tip
I learn something every day. Thanks, Jack.
Re: wedges
I learned this watching Curtis Buchanan making chairs.
One interesting thing, If I understood it, was to taper the tenons and holes so they are larger on the bottom side of the seat and the tenons are smaller on the top and fit into the hole like a tapered cork from the bottom. The the wedge keeps it from falling out. The idea is that as the seat rests on the legs and settles onto them they actually become tighter over time. I suppose this might lead to the legs bulging above the top, and come to think of it, I have seen that.
There's a lot engineering in a well made chair.
