table top finish question
I am refurbishing an antique rolling liquor cart. It had a shellac finish. I had to sand the top bare due to damage. I stained it. I don't have access to shellac flakes around here so I used Zinsser Bulls Eye shellac clear transparent. the can is only a week old but who knows how long it sat on Walmarts shelf. There is a lot # but not a date. My wife doesn't want a glossy finish so I was steel wooling it down and the pressure from my fingers leaves a mark. Had to carefully steel wool those down. It cured overnight for each layer. This worries me since we will be placing a lamp and possibly a few nick knacks on it. Should I put a layer of Polyeurethane on it? I am going to put a coat of Johnson's paste wax on but that won't add any real strength to the finish.
Re: table top finish question
John, how "antique" is the antique rolling liquor cart?
Assuming that the shellac is de-waxed, I would give it 3 or 4 coats of General Finishes water-based poly, Satin. This will leave a clear, but non-plastic finish which will not yellow over time.
I have used this on several surfaces where I want a "natural" look, yet waterproof and durable. One was our kitchen (in hard maple) ...
Do not attempt to paint the poly. It dries too quickly and leaves streaks. Ditto a foam roller. I found that a combination of grey mesh and a microfibre rag do a wonderful job.
Have a look near the end of this article: http://www.inthewoodshop.com/Furniture/Kitchen%20Rebuild.html
Summary ....
Rub down the shellac with grey mesh (400 grit).
The finish is a little sticky, and it dries fast. I apply it as if it were polish and I was polishing the surface of the wood – it is almost a case of rubbing off the finish rather than rubbing it on. You can do so in small circles, but you must finish (as it dries) by only rubbing along the grain. Using raking light, look for any streaks. Simply rub them out.
Once dry, use the grey mesh to rub the surface with the grain. It not only removes any streaks, which it blends all together, but it seems to raise a shine.
It takes at least 2-3 layers before a shine becomes apparent. The poly slowly builds in thickness. Polishing it as done here only adds a thin coating on each occasion.
Dick Coers
I wouldn’t hurry with any more finish. Some direct sunlight might be in order to fully cure that shellac.
John,
First, check your can to determine if the product is "de-waxed". Bull's Eye has traditionally been a waxy shellac. If it doesn't say "de-waxed" applying any water-based top coat will run you into adhesion problems. Putting wax on top won't help.
Second, shellac doesn't "cure." The solvents (ethanol +/- acetone +/- other) will evaporate fully in about a week. The hardness of the finish depends on a) the presence of wax content and b) the age of the product. Dissolved shellac resin esterifies with time making the resin softer.
Third, if you want the option to use a water-based top coat, do not touch your piece with steel wool; it leaves tiny metal particles that will then rust and make spot on the new film.
Last, if you want a shellac finish and can't mix your own from flakes, switch to Zinnser's "SealCoat" which is a 100% dewaxed shellac. It can also be top-coated with any other type of product.
GolfSteve in Calgary
I've had two similar experiences with shellac. In both cases it was with shellac flakes that had gone bad before I bought them. The flakes took a very long time to dissolve, and then the finish never got hard.
The 2nd problem might be how thick you are applying the shellac....brushing it on? Aim for thin coats. Too many thick coats too fast can leave you with a soft finish.
Leave it for a week. If the finish doesn't harden, then I'd sand it off and start over.
John lucas
This isnt an antique of any value so I'm not concerned with value. Just want a good useable piece of furniture.
I'm going to let it sit for a few more days to see if does harden. Would rather not top coat it if I can help it.
Zinsser shellacs
David Yoho
The only de-waxed shellac Zinsser makes that I know of is the Seal Coat and the aerosol cans of spray shellac. Everything else contains wax. Hope this helps.
Re: The Shadow Do!
William Duffield
Who knows what evil lurks in the Zinsser date code?
The first number after the letter is the last digit in the year it was manufactured.
The second number corresponds to the month. The third and fourth numbers relate to the actual day of the month.
If you forget where you have stashed your secret message decoder ring, just ask Google to search for "Zinsser Date Code".
Old
David Weaver
If it's on bare wood, it's probably old. I had the same experience with a can of finish that I tried to use too long.
Clint Searl
Clint Searl
"Sealer" and finish in one works with a waterborne floor finish. I like Varathane with the aluminum oxide additive. You can dance on it. Rub out the gloss with maroon scotchbrite.
Re: Not sure about the aerosol
David Yoho
Unless they changed the product, the aerosol should be de-waxed.
Dick Coers
Wouldn't you think they would group it with the seal coat if that was the product in the aerosol?
David Yoho
Dick, I'm not totally sure but I think the aerosol shellac was available before they came out with Seal Coat. I'll see if I can find out something from Michael Dresdner and report back.
Michael Dresdner's Reply
David Yoho
I email Michael about the Zinsser aerosol being de-waxed or not. I'd like to thank him for his reply, which follows -
"Are you asking for confirmation that Zinsser aerosol shellac is dewaxed? The answer is yes. They don't say it on the can, but it has always been that way because the wax clogs the tiny aerosol tip.
It's not a gift to users; simply a money saving problem eliminator for them. It also means that you don't have to shake the can, since there's no wax to settle. Thus, no ball bearing in the can."
