I bought a new axe to replace one that has disappeared. The first 3" of the blade has about 5º tapper, then at about 1/2" the bevel is about 25º ~ 30º sharpness angle, but it was done on a belt with too soft a backing, or none, so it rounds on down too wide for the final 1/8". I'm thinking that the 25 -30º would be about right if it were flat right to the edge. I'm sure the 25 would dull more quickly, but not so much in softwood which is what I'm intending to use it on.
Are there any Abe disciples among us with plenty of time on the handle end of these things?
The proper geometry is kind of complex, but you want a slightly convex cheek leading up to the edge gradually. The "cheek" bulge makes it harder for the axe to get stuck if you're using it in earnest for chopping.
Not sure how hard your new axe is, but every decent western axe that I've seen can be draw filed, and many were sharpened with a mill file and only touched up with a stone at the most - they aren't hard enough to need the belt and polish treatment that they often get - geometry is more important (both to sink into the wood and then the cheek shape being slightly convex in both height and length of the edge so that the axe will release from the cut easily).
Be careful using a stone or a file - your axe may be relatively dull before you final sharpen it, but you'll be doing things that are right into the edge or across it and you can get yourself into trouble pretty easily.
probably one of the last groups to use axes and two-man saws professionally is the forest service in remote areas where there's some travel on foot to do the cutting.
They have some excellent videos. Some of the older use videos are also excellent. Note the guy at 2:10 or so felling a small tree in about 20 seconds without taking any hard swings.
What could possibly go wrong!? I guess that isn't such a new concept. Not so long ago and maybe still does, that would be called "Deer Camp", which reminds me of a story.
Twenty years ago a tornado ripped right through Little Rock, and my shop was right on the edge of the path. Many homes were totally destroyed, and a whole lot more needed new roofs. After trying to find someone to give me a quote and work it into their schedules, I remembered that my neighbor from my hometown had a roofing business, so I got in touch with him. He got right on it, and at a better price than all the others.
When they got here, one of the workers was missing a leg below the knee. I ask him what happened, he told a story about he and the other hunters standing around a fire telling stories drinking. He ended up getting pretty drunk and in an argument with another fellow. He said he finally went after the guy with an ax. The other guy who had a shotgun, kept backing away warning him to stop, but he didn't so finally he shot him in the leg.
Thanks for the sander tip Dick. That is what I've been using on some other old tool that I've been bringing back into shape.
I have a 4x36 belt sander in my shop that I use for sharpening. It is a horizontal sander so I can comfortably and safely sharpen axes, and chisels. I keep an open bottle of water close to the sander so that I can dip the chisels as I am sharpening them. For knives I use a 1x42 belt sander.
There are leagues, and sanctioning bodies. Daughter just loves it. It's a good thing for her after an incredibly ugly divorce and custody battle with a lying narcissist. Wait a minute, maybe I should take that up!
I’ve worked on it here in the shop, starting with a belt sander to flatten the main bevel, then followed with a 8” mill bastard on the secondary bevel, followed by a medium and fine diamond hones that I mounted on handles. I’m not sure I have it down where I want it to be yet though. I’ll need to get down to my wood lot and try it out before I make adjustments.
I saw them using the puck in a couple of videos. I think I can do better with what I already have though.
I always sharpen axes with a belt sander. I have used the 1x42, and 1x36, as well as 2x72. They all work pretty well. The small ones usually have a place where the platen gives way to unsupported belt. If you play the angles you can use the stiffer area near a wheel or the platen area to grind flat, and that falls off as you move away from the support. This will grind an ideal convex grind. There are fancier systems that use something like a bandsaw tire supported on multiple wheels over which the belt runs, but I get a good enough result from just the slack belt.
