Which bandsaw tooth number and type
ebd
I am making finger joint boxes by using a router to cut dados/slots into the sides for the top and bottom. Then I glue it up with the top and bottom floated in the slots. When the glue is dry I cut the box top from the bottom.
To take the thinnest kerf I want to do the cut with a bandsaw. Since the sides are 5/16" to 3/8" thick and the ends are up to 6" I'm at a loss as to which bandsaw blade might give me the best result.
A 3 or 4 tooth would be fine for the ends but too coarse for the thin walls of the sides. A very high tooth count clogs and burns when cutting the ends.
Is there a tooth count and tooth type that would work for this application?
I called woodcraft bands for advice and to order but was told he didn't sell single blades and I'd have to call back as he was busy.
