20 year old paint is best quality S&W semigloss to be replaced by best S&W semigloss. The walls certainly need some sort of preparation. What?
The wood trim, custom run poplar patterns, was primed and sprayed with oil paint before installation. Obviously can not spray the new trim paint. What to use that will approach the glass smooth result of spraying oil paint?
preparation -I've had good luck with the surface treatments like "Liquid sandpaper". I hear it's unhealthful, and have chosen not to become a career painter with it.
As for the trim, I've had good luck with S-Ws trim paint (pro-something? who knows if it's still the same, anyway), but I couldn't comment on how good it looks on vertical trim. I wouldn't call it glass smooth, but it's sure smoother than any of the mill marks left on the trim under it.
I assume you are concerned about adhesion for the walls. If the lightest of sanding will not reduce the gloss to a level you are comfortable with I would prime the walls with Zinsser Bulls Eye 123 primer. It is water based and will stick to anything, even Formica.
For trim I would brush on Benjamin Moore Satin Impervo. It's oil based and leaves a very smooth, low luster, durable finish. It might even be less shiny than the semi gloss that is on your walls. I'm not sure. But it is a very nice paint. The last time I bought it, which was several years ago, the sales clerk joked that I must be painting a lot of metal. The paint was always intended primarily as a coating for wood trim, but as the rules for paints got stricter the only way they could market it was to claim that it was a paint intended for metals.
I just repainted a bathroom that was originally painted with gloss oil based paint in 1996. I agree on the recommendation for Zissner 123 Bullseye primer. Before priming, I sanded the walls with 80 grit using a ROS and washed with TSP. I had zero problems getting good adhesion - even when I taped off freshly painted areas there was no pull off.
The topcoat was Benjamin Moore Regal Select (pearl for the walls and semi-gloss for the doors ad trim) and its flowout was terrible. The rolled areas look good but it was impossible to get a brushstroke-free smooth finish off the brush, even if I added Floetrol.
Many years ago I painted the whole house using Pratt & Lambert Gold - that stuff flowed out beautifully. A few years ago I used Pratt & Lambert Accolade acrylic interior semi-gloss to paint new interior window trim. It flowed out nicely and gave an almost brush-stroke free look.
