Bandsaw blade question
Clementine
I have a 14" Ridgid bandsaw and need a 93.5," 1/4" blade. Occasional and general use only. $30 or so. Timber Wolf and Starrett look like solid choices. I saw that the big box stores sell Bosch for about $10 to $12. I always thought Bosch products were very good quality, but this price makes me wonder. Any input would be appreciated (Please, no fighting or name calling).
Re: Bandsaw blade question
Michael van pelt
I believe you will find that “Bosch” just put their name on the box! I believe they do not manufacture the blade themselves. It likely will be a low end quality blade. I am a big fan of the TimberKing, Olsen, and Carter! Good Luck and happy woodworking!
I pay less than $10 that to have them welded up at Misenheimer from Starrett or Lenox stock rolls. Blades that long should not cost $30.
Mark Nowicki
I pay about $16 (Canadian) for Olson blades. They work fine.
Don Stephan
Just like band saws, hammers, and hamburgers, different choices will have different prices depending on many factors.
I like Timberwolf/Suffolk, because they have several different tooth designs for different applications (green wood, thin plywood, thick dry hardwood, et cetera).
An oft repeated line is ask 10 woodworkers their favorite brand of chisel, tablesaw blade, or bandsaw blade, and you might get 11 different responses.
Identify the type of material you want to cut, the material thickness, and the tightest radius, and then find a suitable tooth design and blade width.
It can also depend on what your intended use might happen to be.
I like Delta and Timberwolf for 1/4" blades that I use for cutting on my 14" Delta.
I prefer the wider Timberwolf or Wood Slicer if I am trying to resaw on my 14" Delta.
Check the Woodcraft link in Marketplace Please
Clementine
I'm going with the Timber Wolf at Woodcraft. I tried the Marketplace link:
PLEASE VISIT OUR MAJOR SPONSORS
CLICK THE BANNER TO VISIT THEIR WEBSITE
Nothing worked, so I got my son who speaks computerese and he said it's the web page, not my computer. If someone could look into this, I would be glad to go through WoodCentral.
Re: Check the Woodcraft link in Marketplace Please
Brad Chenoweth
I just checked and it worked fine for me on both my phone and computer. My guess is it may be your browser. I use either Firefox or
Microsoft Edge.
Brad
Google "Timber Wolf blades dull quickly"
Dick Coers
You'll find quite a few unhappy customers.
Bimetal only
Clementine, seek out a bi-metal (HSS) blade. These will last several times that of the cheaper, carbon steel blades.
Others here - Bill ? - can probably provide sources. These cost a little more, but make up for it over time.
Banner update
Clementine
The banner link works just fine with Microsoft Edge. Still not working with Firefox - probably some little box hidden somewhere that needs checking. Ignorance is bliss until it's challenged.
When I had a bandsaw...
David Weaver
..I used bimetal and timberwolf blades. The timberwolf blades need to be sharpened regularly, but they weren't in a constant state of "sort of dull, sort of sharp" that bimetal are.
I didn't like their value proposition at first (they're better than cheap carbon steel blades for durability, etc, but not like bimetal or carbide). Once you learn to sharpen them quickly with a burr, they'll pretty much last as long as the band lasts without needing commercial attention of any type.
Rockler 30% off bandsaw blades
Michael van pelt
Just got an email. Rockler has selected bandsaw blades Olsen 30%off.
Re: When I had a bandsaw...
David, I sharpen all my own bandsaw blades - carbon steel, HSS and carbide - have done so for many years. Bimetal get very sharp, as sharp as carbon steel if you sharpen correctly. They last many times longer than carbon-manganese steel, such as Woodslicer, which I had the misfortune to purchase.
never had one of those...
David Weaver
..woodslicer - never purchased one.
Most of our woods here don't really demand bimetal, though it's stylish for people here who don't want to learn to maintain anything. It'll probably also be limited by band life.
I no longer have my bandsaw, but it wasn't as nice as yours and it preferred the timberwolves (probably due to additional set - it wasn't accurate enough to do without it).
At any rate, within 3 or 4 sharpenings "bang", and that was the end of that.
Misenheimer
Yonak
Bill, does Misenheimer do business on-line or they mostly a local source in your area ? If one can do business with them on-line, I haven't been able to figure out their website. Do you use it ?
Re: Misenheimer
They are not far away. I usually just go there. Sometimes I have mailed stuff to them. Their phone is: 423 587 4300 But, everywhere will have a saw shop or welding shop that welds up blades.
>>> Clementine 3/14/2020, 5:38 pm
If you are interested in a local supplier state your secret location and someone may have a suggestion. There is a very good bandsaw blade shop in Knoxville TN near me.
Wiley Horne
Here’s one that will be delivered to your door:
https://www.amazon.com/Olson-FB14593DB-6-TPI-Blade-2-Inch/dp/B0031JUM50/ref=sr_1_7?dchild=1&keywords=Bandsaw+blade+93.5&qid=1584306198&sr=8-7
I like the Olsen blades. If 6tpi is too many, you can get 3- and 4-tpi blades from the same source, but they will be 3/8” or 1/2” wide.
Wiley
Mail order Lenox (they have 1/4”)
Wiley Horne
https://www.bandsawbladesdirect.com/lenox-flex-back-carbon-steel-band-saw-blades
Wiley
AZ in Colorado Springs
Timberwolf blades are made by Suffolk machinery. Look them up and call them (you don't order the blades on line). They're about 1/3 the price of woodcraft that way. They arrive wrapped in newspaper in a flat rate USPS box.
Fixed the link
Clementine
The computer son did a second look at my Firefox and found where there was an ad blocker to prevent unwanted ads from popping up almost constantly. That works fine for watching YouTube, but it was also restricting things like banners on this site. He clicked "something" to allow the Wood Central banner to show, while still blocking ads the way it had been doing - the best of both worlds.
Thanks for all the good advice and recommendations.
Re: Firefox privacy settings
Martin
I have similar problems with Firefox and I found it was due to the privacy settings. I have mine set to
10 on a scale from 1 to 10. This is driven by my companies extreme and strict internet policies.
The far right menu in the Firefox window, the three horizontal bars, open and go to the Options
selection, there is a gear looking icon next to Options. A new window opens, then go to
Privacy & Security option with the Lock icon. There is Standard, Strict and Custom. Mine is
Custom and every box is checked.
I have to revert to Standard for some of my companies websites to bring up optional window type
menus that appear on the web page. If I use Chrome or Internet Explorer I never seem to have a problem.
I also have a few pop up blocker addons in Firefox. However, when I roll back to Standard for Privacy &
Security, I have no problems with optional window type menus.
Re: Google "Timber Wolf blades dull quickly"
David Weaver
I recall that being a big problem that some had when I got mine. That's what led me to buy a defective $175 Laguna carbide tipped blade. The feedback from others was so positive that I always figured it might be me until I sent the blade to someone else. I tried and tried to figure out a way to use it, even just for ripping, but it wasn't made right and had no set and would bind itself in the guides on a low height cut.
Can't well go back to a salesperson at Laguna who had quit by then and tell them the story that you tried to make their stuff work but it was no good. That saws wheel turned out to be out of round, too, but it's long gone. I never measured just how much until the buyer was in my shop, which resulted several hundred more to compensate for the fact that he'd want to pay someone to fix it.
I may have been unhappy with the tw blades had I not taken to sharpening, but they cut the nicest of all of my blades and sharpening sort of made their life a non issue.
I'm sure they're not a great deal for most in the market but their extravagant cost turned out to be one of the least expensive lessons with the whole experience of that saw.
