Installing the berries
First, I don’t recommend scratching Line and Berry decoration on a finished drawer. Being able to rotate the panel easily gives one the ability to orient the scratcher for optimum ergonomics, to say nothing about the stress of scratching on a finished and fitted drawer. But, I wanted visiting granddaughter to assemble the drawers when she visited. The decoration is to be a surprise when I deliver the dresser. A practice panel relieved some of the stress. Like a lot of woodworking, practice makes doing this decoration easy.
I am proud of the invention shown in the picture. It is a template for making centers of the berry clusters. I prepared it by scratching 3 near tangent circles on clear plastic with a divider. It is used to orient the berry cluster and mark the centers for drilling.
Berries look best when their position relative to one another in the cluster is not rigidly uniform. On the other hand deciding where to locate the centers for drilling is difficult if done with no guidance. I invented the template to aid this step. The template is positioned at the end of the string segments to achieve an attractive orientation of the cluster and the centers pricked with the tool in the picture.
When it comes time to drill the holes with a spur bit I purposely locate the tip slightly off-center of the hole for some centers. Because of potential overlap one berry hole at a time is drilled and its berry installed before drilling the next hole
The berries are glued in and the whole affair planed smooth.
Re: Installing the berries
Don Stephan
Stunning work. I especially appreciate the effort to make the berry placement not resemble sterile machine perfection.
It is not hard to do
Not stunning, but I would agree with 'kinda neat". This decoration looked impressive and daunting when I first encountered it. I am posting this work to introduce it to others and encourage others to try it.
I had the benefit from a few hours with Steve Latta to boost me up the learning curve. Once demonstrated it is easy to do. One can learn from Steve's video. I can't recall all the small steps that make it easy, but they are all in Steve's video.
Anybody that can do the rest of building stuff can easily learn to do this decoration. It is certainly way easier than making a well fitted drawer. Just to demonstrate that I can, I fuss with intersections more than necessary to get them perfect(most of the time). This pattern will be viewed from several feet. It would have to be pretty bad to not look good from several feet.
