OT - Tile
OT - Tile
OT - Tile
Have a piece of marble tile on a tub surround that's popped loose. I'd rather not get into chipping off the original thin-set, but not sure what to use to re-stick it to the structure while keeping it level with the surrounding tiles.
Suggestions?
tia
Re: OT - Tile
Careful
Dick Coers
Isn't marble a stone that will get a shadow with a solvent based adhesive?
Re: OT - Tile
Yup
That's why I was considering either epoxy or an acrylic contact cement that will evaporate before joining.
Since the the existing thin-set has a pattern that matches the tile's back surface, looks like a thin butter of thickened epoxy will be most likely to get this put in place.
Thanks gents
m
Re: OT - Tile
Clean it some
Mike L
then liquid nails it into place. I have done this to a lot of tiles that have come loose over the years.
Re: OT - Tile
Re: OT - Tile
Yonak
There are some double-sided tapes ("supervisor tape", as a friend used to call it) that you need a crow bar to remove.
