REAL MILK PAINT
Entry hall table for a niece: Part 9
The legs are on. I must admit to mixed feelings at this stage. This is not my style of leg, but it is what my niece wants. Perhaps I will feel differently with a finish on the wood.
The tenons were kerfed for a wedge ...
Installed in the bases ...
And glued into the socket. Note that only the first third is glued. The rear is free to move ...
The bases have been shaped to reduce their impact ...
The legs were evened up ..
Side view from underneath (one does not see the base otherwise) ...
#EntryHallTable
Re: Entry hall table for a niece: Part 9
I like your engineering on the leg attachment. I can't imagine a more secure arrangement. I presume you will add a couple of screws to where the glue isn't?
Clint Searl
Clint Searl
If it's glued at the front, what's the point of a screw at the rear?
Clint
The screw is not to prevent it sliding back (an elongated hole encourages this). It is just to prevent the tail (base) twisting in the pin socket (sliding dovetail) since there is no glue there to apply this force.
The force comes from the splayed and angled legs. They will want to cant outward, and this becomes more so when the three drawers are filled and a vase of flowers is placed on the top.
screws
Supporting the glue joint with screws is prudent for the engineering reason Derek describes. Additionally it is likely this stressed, small area, cross grain glue joint is going to weaken and possibly fail over time if not strengthened. Screws will ensure this leg assembly remains attached for generations.
Philip F Duffy
Derek, A beautiful piece, once again. Quick question: Is there any way for the legs to be removed for purposes of a move to a different town/location? P.
good point
But I would rest easier with screws and glue. If I had to move it I would do it upside down.
Philip, the legs are attached permanently and not intended for removal. They could be removed in the event of repairs being needed, since the attachment is hide glue.
This will be the third piece travelling from Perth to Sydney (think New York to LA). The first was a coffee table for my son, which I designed as a flat pack and took on the plane with me (!). The second was the coffee table for my nephew, which went with a service. From this I later learned that tables travel upside down (and boxed). Therefore, so shall this one.
I agree with you about the legs, not to my taste but well done.
I have watched a few YouTube videos by a chair maker, Curtis Buchanan, who has made a name for himself making Windsor style chairs. If I understood what I was watching, he made the mortice for the legs tapered from the bottom to smaller at the top. I think this means that time and weight will drive the leg further into the hole and make it tighter. Before watching, I thought the hole was larger at the top so the wedge would flare the leg, making it impossible for the leg to fall out. Now I think I was wrong. And, one other note, he only glues the wedge on one side. This allows the slot to open if necessary from some sort of wood movement.
Question, cross grain drawer? I see you have all the grain aligned consistently to allow for cross grain expansion and contraction. I know your wood is as hard as woodpeckers lips, but how will this effect the action of the drawers. They are not likely to get a lot of use but will they slide smoothly?
Hi Barry
I am not certain how Curtis glues his wedges. The legs I built are also wedged . They are not going to loosen or drop out. Further, unlike a chair, a table does not have the racking motions which tend to stress leg joints.
The smoothness of a drawer working does not, as I understand, have anything to do with the hardness of the wood used. It has to do with fit, and then expansion, as this affects the fit. This is why I am so particular about grain direction. I imagine that hard woods probably act less like sponges than soft woods, and they wear better.
Clint Searl
Belt & suspenders
