THE WOODRAT IS BACK!
Barrister bookcase door - hardware?
Henry (Raleigh NC)
I have installed a built-in cabinet, and now have decided to install a door on the bottom shelf. For a variety of reasons, primarily space constraints, I believe the best choice is an upswing door, like that on a barrister bookcase. This is an inset door where the top moves to the back when the door is lifted.
My question is about hardware.
- Is this made with a simple pin riding in a track? if so how does one ensure that with uneven movement (left to right) that the pin stay in the track?
- Or is more sophisticated hardware available?
I have been thinking about trying to adapt drawer slides, but haven't quite wrapped my head around it.
Thanks,
Henry
Re: Barrister bookcase door - hardware?
Almost yes to both
Dick Coers
There is fancy hardware.
On wood version there are pins that ride in grooves, PLUS there are fixed pins in the front of the track for the doors to rest on when the track pins are heading towards the rear.
Buckaroo
OT--DEREK, WHAT DOES/IS ROSSMOYNE, 6148 ??
PLEASE WITH SUGAR ON IT!!
Buckaroo
OT/ DEREK, SURE HOPING U'D HELP OLD COUNTRY BOY WITH THIS!!
Craig Spacek
You can get hardware that helps prevent racking as you slide the door in and out. I’ve used this type with success. The metal on metal squeaks a bit but I can open and close the doors with one hand from a corner without the door sticking at all. Maybe someday I’ll try a little wax to see if that quiets it down a bit.
https://www.vandykes.com/restorers-classic-bookcase-equalizer-hardware/p/225721/
They also sell a more expensive version that I’ve not used.
https://www.vandykes.com/equalizer-hardware-for-bookcase-s4871/p/204777/
Josko Catipovic
There's a FWW article (Sept '92) on how to do it with a spring from a tape measure and a very thin (1/16") router slot cutter.
Thanks - my choice for hardware
Henry (Raleigh NC)
Having been through a bit more searching, including Van Dykes (where the listed instructions were simply a parts diagram...), I searched the term 'flipper door' on Lee Valley (another great source of hardware). Calling them (that is LV) I was provided answers all my questions and I am likely going to implement their Concealed Door slides, with a set of soft close Blum hinges (as suggested by customer service). Total hardware costs are about $35 plus whatever shipping costs, which is more than the least expensive option, but significantly less than the bigger package deal at Van Dykes.
- LV Concealed Door slides: https://www.leevalley.com/en-us/shop/hardware/slides/side-mount/48629-concealed-door-slides
- the associated hinges also needed: https://www.leevalley.com/en-us/shop/hardware/hinges/european/66792-blum-self-closing-clip-top-soft-close-hinges
The reason that LV customer service suggested these specific hinges is that rather than mounting the hinge base directly to the cabinet, these hinges have a mounting plate that is first installed and then the hinges are slid onto these plates. This eases the hinge installation, and that was a concern; I will have my head inside a cabinet and the rest of me inside a too small bathroom, and will be installing top mount hinges. Ease of installation will make a difference here, even though this is a one-off.
I have not yet determined the final dimensions of the already installed built-in cabinet (opening for inset door and depth of cabinet), but will update this thread when I manage to finish this project.
Henry
Keeping the doors from racking
Yonak
Henry, on my barrister-style bookcase, the doors are constrained from racking by the cabinet. The doors are within 1/16", either side, of the cabinet width.
Re: Keeping the doors from racking
Henry (Raleigh NC)
Yes I though of that constraint later.
Can you tell that I have never even been in front of such a beast? Only exception I think is the case of the office cabinet, a metal Steelcase unit, but even there I ignored the hardware.
Henry
jessecloud
I did a barrister door project about a year ago. Main thing I learned was that with off-the-shelf metal slides (I tried Rockler), you are constrained to the depth that the hardware was designed to handle.
After fooling with that issue for a while, I used a plan from wood magazine that has all wood shop made pieces. With this approach, you cam make the mechanism fit whatever dimensions you need. You can find the plans (on sale for a small fee) by googling "barrister bookcase plans".
I recommend throwing together a "dummy box" with the desired dimensions just for the purpose of trying out the mechanism. I learned a lot that wasn't obvious (to me at least) until I tried the real thing.
Never had a problem with racking or alignment.
Fun project once I figured out the mechanics.
