Pedestrian Moxy-lite vise goes to work
First, I want to thank all that posted over the years about their efforts to make Moxom vises. These posts eventually goaded me into trying one, although I could not bring myself to make a nice one.
I have 6 drawers I need to make now and several more later. Time to try it.
1. It secures the work better than my half assed previous arrangement leading to less vibration sawing which in turn leads to being able to use a coarser(faster) saw.
2. The work is elevated where I can see better.
3. An unexpected bonus. With the base line a little above the vise top face I am better able to judge that the saw is parallel to these faces leading to being able to saw to this line on both front and back without stopping and checking the back. A substantial time saver.
One of the main reasons I put off making one was the complexity and cost of some versions. The posts of the Moxy-light versions tipped the balance. The cost of this one was two bolts and a bdft of 8/4 maple. There is no cost or time excuse not to make one.
Re: Pedestrian Moxy-lite vise goes to work
Chuck
Very nice, Function is what is needed, beauty is nice but not necessary all the time.
Well done.
Good for you Bill. We all knew that you would find benefits once using a proper Moxon vise. :)
Incidentally, these vises need not cost much, either in time or money.
This was Chris Schwarz' version that started most of us building one: a screw box for the arms is the only possible expense ...
I looked at it and - of course! - had to modify it (to make it easier to clamp to the work bench with either clamps or a hold down). I have a screw box ...
Then I began to modify it for ease of use. First a better handle ...
Then an integrated spacer (to lift the work piece above the chop when transferring marks with a knife) ...
It was only after some years of using this vise that I decided to get fancy shmancy and built the current one. I sold the old one for enough to pay all the materials and parts.
Wheels ala BenchCraft (but not BC ... much cheaper) ...
A flip up spacer that also doubles as a clamp. This is fantastic! ...
Recently, I added springs, which aids in opening the Moxon ...
It is all a bit of fun. The most basic version (at the start) is all which one actually needs. In truth, however, the current fancy version is not only fun to use, but it actually works better than any I have used. As you have discovered, this translates into better work.
TomD
That is a nice one. If you had hold downs rather clamps it would be right up there.
I am working on a really pedestrian one, that is basically just vertical dog holes with hold downs. Get in line. :)
