OT Ideas please -- Cymbals
Gary Smyth
1. Looking for ideas. Before the past holidays my neighbor asked if I wanted several used cymbals he was replacing for his drum set. There are eleven in number and vary in size from 14” in diameter to 6”. Some are good, some cheap. Condition --almost “new” to dinged from travel. I thought I would clean them up and might convert some as light reflectors, or perhaps as a garden rain chime, a “gong” type doorbell, or even a background/mounting “frame” for an art/sculpture display. Nothing, so far, seems to mesh with my idea of how to convert them from what they are into something repurposed. I’m stymied. Ideas?
2. I also can’t find anyone capable to reshape some of the large diameter ones into a dome/bell shape? Where do I look for someone who would be able to rework a cymbal? Local shops and music stores seem to say “huh. Manufacturers I’ve contacted don’t seem interested. Wish I knew more about metal turning and tools!!
Re: OT Ideas please -- Cymbals
wood spinning
Are they made of brass?
Woodturners who dabble in metal spinning could do that. John Lucas has done some. You turn a wooden form to the desired shape, grip the metal firmly on the lathe and while spinning push special tools firmly to reshape the metal to fit the form. (A cymbal would need a huge form and a large lathe. If you found someone to do it it probably wouldn't be cheap.) The aircraft industry uses this as do companies who make cookware. It's incredible how much you can deform metals.
A wood spinner did a demo at our turning club once. He made and sold trumpet mutes for income and decorative things for fun.
You can ask Sir Google for info on woodspinning.
Leo Cuellar
Re:  OT Ideas please -- Cymbals *LINK*
Leo Cuellar
Another option would be using a deep throated shrinker/stretcher and english wheel. These would be best for dealing with the damaged cymbals.
https://www.youtube.com/watch?v=aD0KsVmHc-w
interesting metallurgy
Dick Coers
I drilled some holes in one of those a few years ago. It's pretty hard brass. Spinning or reforming would require a annealing, and then not sure how soft they would stay. Would probably work harden pretty quickly.
annealing brass
Repeated annealing is a necessary part of the metal spinning process when spinning copper and brass according to our metal-spinning demonstrator. He kept a propane burner at hand and annealed quite often since they work harden quickly.
These metals are annealed by quenching while hot, unlike steel.
I learned that when machining brass that had been work hardened when I bought it as scrap. Hardened, it was extremely difficult to drill the 5/8" diameter hole.
When buying new stock I get 360 "free machining" brass.
Use for cymbal
Howard Pollack
Send one to me, I'll buy it from you. It could be the worst one. I've been looking for one to use as a doorbell. ;) -Howard
Need contact info
Gary Smyth
My email: executive3@comcast.net While I'm determining what to do with the largest, I can send other. 7249424204
Address for sure, phone helpful.
