Question on prefinished UV plywood
Tim Greif - West of Chicago
Seems that the term prefinished clear UV plywood is all the rage these days for most kitchen cabinets. It's used primarily on interior surfaces for durability. Can anyone tell me exactly what clear UV finish actually is?
Re: Question on prefinished UV plywood
Some of the stuff that I have seen is a non-yellowing acrylic coating that is supposed to be UV resistant. YMMV
Larry Edinger
This versatile modified acrylate finish is tough
https://www.columbiaforestproducts.com/product/uv-wood/
This what I use
John McGaw
I always figured that it must be pretty much the same stuff that is used on pre-finished hardwood flooring although YMMV. I know that some of the floor finishes are pretty much indestructible under normal circumstances.
Larry Edinger
It is Tough Stuff !
Keith Newton
JL, I don’t think UV would be an issue inside a cabinet. I’m guessing this must be using a UV cursing process, which has low or no VOCs and a very quick cure .
The stuff I've seen says that it is UV resistant and non-yellowing - and it is on the exterior as well as the interior of the plywood.
As far as a UV curable finishes - they are out there. A friend who is a luthier (if that's the appropriate term for someone who makes guitars) uses UV curable finishes. He has a "light box" in which he places the guitar after he sprays on the coating. I am uncertain as to their chemistry.
Menards says;
Dick Coers
This plywood features a clear, thick semi-gloss epoxy acrylate finish and a four coat ultra violet coating system.
Another source;
Type of plywood finish featuring a clear, durable top coating to add toughness, resisting to scrapes and chip. UV coating is basically a compound that is applied to wet wood and then instantly dried by ultraviolet light. Several different types of compounds are used to coat wood. UV finished surface is expected to reduce VOC (Volatile Organics Compounds) emissions. Different sheen level (or gloss level) is available such as UV50, UV40 and UV30. UV plywood is prefinished hardwood plywood panel featuring a clear, durable top coat, which will add toughness, resisting scrapes, chips and the effects of solvent wipe down to plywood.
Re: Menards says;
Bruce, a MN Galoot
I’ve used some of the menards stuff for shop projects, but I wouldn’t use it for finished cabinets, only because I don’t prefer wood colored that light. The finish is rock hard and resistant to scratches.
Re: Menards says;
Dave Bair
It creates ceramic-like chips when dimensioned using a circular saw. Wear gloves when handling or your hands will suffer a thousand tiny cuts you will discover the first time you wash up.
