Floor protector?
Floor protector?
Floor protector?
We recently got some pre-finished new flooring w/ aluminum oxide incorporated into the finish.
For our more stationary furniture, the felt floor protectors work well.
Not so much with the dining room chairs - they have plastic "buttons" on the end of the legs. The felt floor protectors (circular) keep falling off - probably because the buttons are smaller than the diameter of the felt pads.
Do we really need the felt floor protectors on the chairs? If so - does anyone have a better solution for a way to attach them? The sticky backing isn't working that well on the buttons.
Re: Floor protector?
A better question
David Yoho
The better question is do you really need to keep the plastic buttons? Sooner or later they will cause marks on the flooring and the felt pads will not stick to them. I'd remove them and attach the felt pads directly to the ends of the wooden legs. You might consider using some type of epoxy because the sticky backing won't hold long.
Also... *LINK*
David Yoho
A quick look on Lowe's Website shows a selection of felt glides that nail on. You can find them at any number of places too.
Here's a link below to Lowe's so you can have a look.
Glides at Lowe's
Re: A better question
Ditto what David said. We have felt stick-on pads on our counter stools and they have stayed put for a couple years, on a rough tile floor. When they wear off, they'll be cheap and easy to replace. I'd lose the buttons.
Ralph Lipeles
I made my own floor protectors. I first sharpened a piece of thin walled 1" diameter pipe. That gave me a tool for stamping out 1" diameter disks from 1/4" thick felt. I then did the stools one by one. I turned them upside down and sat them on the counter. I swabbed the existing metal feet with alcohol and also sanded each one with sandpaper. That gave me a clean surface to glue the felt pads on. I mixed up some 2 part epoxy and spread it on one of the metal feet. I then placed one of the felt pads on the foot and held in firmly in place with 2 pieces of masking tape at right angles to each other. Repeat for the other 3 legs.
I did this about 10 years ago and all 16 pads are still in place
Don Stephan
New felt should be clean and soft. But if placed on a bit of sand or other grit, it might become imbedded in the felt. Perhaps it would sink into the felt rather than remain on the surface, but there may not be an entirely risk free material to place on the bottom of furniture legs.
I hate to dash your hopes, but.....
Tim Greif - West of Chicago
I hate to dash your hopes, but I've lived your battle for over 30 years. I build my home in 1989 and have hardwood floors throughout the kitchen and other rooms. We have a country table and four chairs along with three kitchen bar stools at the kitchen island. I have been putting felt pads on the bottom of all chairs and stools from day one. When you first put them on, it's wonderful. But if you're like us, our kitchen really gets used. No matter how careful you intend to be to that nice floor, stuff happens. Don has it right about trapping stuff. Any gritty material that gets dragged in and finds its way near the chairs will get trapped in the felt and eventually turn that little protective pad into a mini abrasive pad. If you're really anal about sweeping and vacuuming all the time, like daily, you may win the battle. But who really does that? Eventually scratches will begin to appear. Next, you'll sort of forget about the pads until you discover they're completely flat and are doing next to nothing. You'll replace them and the cycle starts over, with you swearing you'll remember to renew the pads more regularly.
Scratches are going to happen. In the 30 years we've lived here, I've had the floors completely refinished once and had a scuff and coat done once. I'm about to do it again this year. We don't remove our shoes when we walk into the house like some people do. That would certainly help. If you have kids or a dog, you will definitely lose the scratch battle no matter what. In my mind, a hardwood floor finish is a consumable, much like carpet. Eventually is needs replacing because you walk on it and it's not durable like tile. Accept that and admire its beauty as it ages. Good luck.
Bingo!
Larry Rupprecht
We also have hardwood floors throughout our 102 year-old bungalow. The current floors are new about 20 years back, replacing the original qtr sawn red oak that had a wood-fired kitchen stove and an oil-fired heater on them for maybe the first 30 years....and no sanding or refinishing in 80 years. Now the "new" floor is abused by me with work shoes, a feisty Beagle, and two counter height stools with those worn out felt pads. My son calls the scars on my floor the character marks of family life. We love the sounds this floor gives us. The Beagle can't hide from us as her toenails announce her movements. Damp shoes give a squeak that makes us smile. Plus the floors are so easy to return to clean.
Sometime in the next 20 years [I'll be over 90] we will leave this home of now 40+ years and will have the floors sanded and refinished...if the new owners agree. They may love the look!
Don't use the nail on ones. Sometimes the plastic button or felt pad disappears, leaving the nail behind and it ruins the floor finish. DAMHIKT
