water mark resistant finish
Jack Guzman from Maine
I have a small side table that I painted with milk paint and finished with a wipe on oil/spar varnish. I finished it this way because it is intended to be a companion to a similarly finished windsor chair. Anything moist leaves a watermark on this top. I want to coat it with something so I can use it for my morning coffee or whatever without staining it.
Any suggestions?
Re: water mark resistant finish
I made some tables for a local restaurant and used conversion varnish. It has held up very well.
T.
second conversion varnish, or
any finish approved for kitchen use. We wash surfaces of furniture done with conversion varnish. However, in your case if you have no need for a gallon or 5 of conversion varnish, a urethane varnish should do just fine. We wash the floors done in urethane varnish. I am surprise that what you used didn't work. Are you sure it is not lacquer?
Re: second conversion varnish, or
I'm thinking I may not have gotten around to getting the finish coat on the top. I'm going to try straight spar varnish by brush. I'm sure its not urethane.
Dick Coers
Could be you just need more coats of your finish. I know some turners that put on 8-10 coats of wipe on poly.
