Cleat Shelf Supports
John W Foster
I am about to build a split (divided) bookcase for my daughter. It will have a center divider to allow 2 banks of shelves each about 18" wide. She would like a basic traditional design, so I was going to use cleats to support the shelves, but I would also like the shelves to be adjustable. This raises several questions.
1) If I put a face frame on the sides and center piece that is wide enough to hide the cleats, that would mean that the shelves would have to be tilted left to right to clear the overlapping face frame when being adjusted , this would mean that there would be a minimum spacing required on the cleats so that the cleat above the desired one would not interfere with getting the shelf in the proper position. Brush up on my trig?
2) I don't recall seeing bookcases with several unused cleats between shelves, is this uncommon? The only effect I foresee is that it would hold the end book out from the sides.
3) Other than modern peg and hole or metal rail type shelf supports, is there another option I am overlooking?
Any ideas?
Thanks
John
Re: Cleat Shelf Supports
why not pins
What objection do you have of holes and pins? They worked for Krenov - see PIC. Either in brass or whittled wood I have used them in some fine furniture, kitchen cabinets, closets, etc.
Google saw tooth adjustable shelf bracket
Traditional Shelf Supports
Steve Elliott
There are several ways adjustable shelves were done before metal shelf pins became common. One of them is shown in the link below, from a website maintained by a retired British antiques dealer.
Another is shown on Don Stephan's website. If you search for "Don Stephen birdsmouth shelf" you'll find both pictures and Don's construction method.
Re: Google saw tooth adjustable shelf bracket
John Pappas
A variation of the saw tooth. Drill half inch holes in a strip of wood and then cut in half. Best if done with a thin blade....band saw or a Japanese pull saw. Cleats are rounded to fit.
Jim Dillon
John,
Here is a variation on the shelf supports that John Pappas described. While this china cabinet does not have a face-frame, I think it should work in your situation as the cleats are easily removed and repositioned. As an aside, while I like you guys/gals a lot, I am NOT going to move all the china to get a better picture :) . Hope this helps. Jim
