Small hinges
Small hinges
Small hinges
Michael van pelt
Building a production run of gift boxes. Cutting the dovetails on my CNC router got 48 boxes built and ready to install the hinges. Can not get the dollars for my boxes to justify the expense of Brusso and the Rockler hinges are poorly made and the screws are JUNK! A very frustrating day of broken screws
Suggestions on a good quality hinge at a fair price ? I have ordered a better quality screw and hoping this will help! Thanks!
Re: Small hinges
Re: Small hinges
del schisler
try this place http://www.smallboxhardware.com/prodview.lasso?searchfor=hinges&showtype=thumbs&shop=A&-session=Site_Preferences:636D0AAC1d9e7138BAWiQ43AC230
Re: Small hinges
Re: Small hinges
Ralph Lipeles
Install the hinges with steel screws the same size as the brass screws. Then remove the steel screws and carefully install the brass screws.
Re: Small hinges
alternative installation
Drill the optimum sized holes with a number drill and lube the brass screws.
Re: Small hinges
Re: Small hinges
DizD
Ace Hardware is your friend. They have solid brass hinges 11/2" and 2" in broad and narrow size which have steel pins and are well made - almost no play in the joint. For the money - around $4 - I think it is the best value on the market. Look at the end of the hinge and you will see no gap between the pin and the hinge leaf. Sizes below and above those are more typical stamped construction.
Re: Small hinges
Re: Small hinges
Michael van pelt
Wow. Thanks for all the great suggestions! On my way to Ace!
Re: Small hinges
A Big thank YOU!
Michael van pelt
Thanks!
Re: Small hinges
Re: Small hinges  *LINK*
John in NM
Maybe next time around... I really like Lee Valley's hinge selection (though I'm afraid I DO NOT like their new website design - the old was better organized).
For the top notch box, they have an extruded brass hinge that is very high quality and while expensive, not in the crazy Brusso territory.
For inexpensive, your local hardware is probably the place to go if you want solid brass. I do like LV's brass plated steel hinge to though, for a very small hinge the steel can be a good idea.
https://www.leevalley.com/en-us/shop/hardware/hinges/cabinet-door/40468-extruded-brass-x-narrow-butt-hinges
Re: Small hinges
Re: Small hinges  ACE HARDWARE
Michael van pelt
Thanks for the tip Ace Hardware. The hinges are well built and the screws that come with the hinges are very well made and worked wonderfully! Thanks!
Re: Small hinges
DizD
Glad it met your needs. The screws are brass plated steel, which are more forgiving. That and the price point make these a winner. BTW, do you use the hinge installation that creates a stop for the lid?
Re: Small hinges
Michael van pelt
I built a jig and use a small plunge router to route a mortise for the hinges. Some boxes I just face mount the hinges and use a small chain stop as well. Thanks again!
