Hack. Scroll saw blade in coping saw frame.
Virgil Johnson
This is a hack instead of a method of fine wood working but someday it may get you back to working wood instead of browsing a web site looking and waiting for a saw.
Last weekend (after watching a video by Derek Cohen) I decide to waste the material between pins on a stack of drawer backs by sawing vs chopping. First problem....I do not own a fret saw only an ancient coping saw. Second problem...The coping saw blades I had were too wide. The local woodworking store had a fret saw but I found it too heavy and I did not like the style. They did not have any small coping saw blades in stock so I bought a pack of the smallest pin type scroll saw blades on hand thinking they would fit my frame. Problem 3... Early Sunday morning I found they were 1.5" too short for my saw frame. After a bit of thinking I came up with a way to fit these in my coping saw and a short time later I was back in business.
Solution...The blade tightening mechanism is threaded 5/16-18 so I cut the head off a 5/16 carriage bolt and adapted the short all thread part to the holder with a nut. I used another nut to lock the handle after applying tension to the blade. The saw cuts really well for a "hack" saw.
