Spray Gun Recommendations
howgor
Spraying 30 kitchen cabinet doors in spraybooth with Fuji stage 4 non-bleeder. Spraying color matched off white precat lacquer. Was thinking of a gravity feed but didn't know if the cups hold enough material to be practical for this type of job. If a standard gun is better what would be best. I have the fuji gun that comes with the turbine, but would like to update to a new one. Thanks
Re: Spray Gun Recommendations
Their gun is OK
spring for the 3M PPS system. You'll like it a lot
Re: Their gun is OK
Larry Edinger
Does the 3M Gun use a lot of Air?
Not A Gun
the 3M pps system is cups and adapters that uses collapsing bags to hold the finish. Allows the gun to be used at any angle, even upside-down. System will fit on most any gun depending on the adapter.
Sorry if you thought I was talking about a 3M gun. The Fuji, designed for the massive (150+ cfm) airflow of a turbine unit, would not be likely to do well with the far smaller output of an compressor.
