REAL MILK PAINT
OT- Sticking Emergency Brake Cable
Tom Norton
The above is on my 2011 F150. Often when I use it the light and sound stay on even after I release it. So I have to use my foot to pull up on the pedal a bit more.
Anyone have experience in lubricating these cables?
Thanks!
Re: OT- Sticking Emergency Brake Cable
Mark Nowicki
I have kept the emergency (parking ) brake lubricated on my 2010 Dodge Journey
with a combination of PB Blaster and FluidFilm.
First I spray the PB on any exposed wire followed up with FluidFilm, any pivots on rear calipers get the same treatment.
Check and lubricate your calipers as well.
Ralph Lipeles
Once you get it free use it periodicly. That will continually scrape some surface rust away and help prevent it from sticking.
Bill Howatt
This is excellent advice and is a common reason they start sticking.
Unfortunately, they can be difficult to free up and if it doesn't happen after a few tries you might just have to bite the bullet and replace it. I don't know the setup on your vehicle but often there is the enclosed cable from the cabin, then exposed cable, then short pieces of enclosed cable to the wheels. They all need to be free.
Bill
Tom Dunlap
If you’re above the salt belt you’re familiar with its rust and corrosion. My Dad taught me that the emergency brake should be used all of the time or never. With automatics I never use them. With manuals...sometimes...sorry Dad 😉
When I buy a new vehicle I find a user group on FB or the web. There is an F150 group just as helpful as the folks here at woodcentral
If I found a sticking e brake cable I’d lube it first then go in and prefer a new one. There’s no convenient place to have a cable not release except in your driveway or the mechanics
Tom Norton
I think for the time being I am going to avoid that pedal!!
Thanks for the replies!
Happy Thanksgiving!
Tom Dunlap
Parking Brake gets you better results
Mike L
The F150forum has a lot of information on these sort of things. I did a fast search and found this thread
https://www.f150forum.com/f38/parking-brake-stuck-355663/
I am sure there is a lot more information you can learn from that site.
Mike
