OT Propane and a Big Easy
Mike L
I have a Big Easy turkey frier. I used to use a propane tank to fuel it. Now I have a large 120 gallon tank for my house I want to use, because I don't have the small tank any more. I have a regular grill hooked up to the house tank currently. My question is can I just take it off my current grill and go straight into the Big easy? Will I need the regulator on the big easy or is it regulated at the tank? I M pretty sure I don't need the regulator but I figure better safe then sorry.
Mike
Re: OT Propane and a Big Easy
Mark Nowicki
Get another small tank.
Jason Roehl in Lafayette, IN
Your Big Easy should have a regulator on it. Use it--it's adjusted for a certain pressure of propane gas.
Personally, I wouldn't be switching things around that are connected to a large propane tank. Too much opportunity to lose a lot of expensive propane quickly. With a small tank, your loss is limited.
Jason
Consult your propane supplier....
John in NM
They will know the answer and perhaps be able to get you set up for Christmas if not Thanksgiving.
In general, I would expect all propane appliances to use the same pressure, and yes, there is a regulator at the large tank. However, propane is a pretty dangerous fuel due to being heavier than air, so leaks are a big deal. Consult the pros and you should be able to get the frier set up as you want pretty easily.
Walter Ahlgrim
Are you sure you want it connected to your big tank?
Once or twice I have gone to use the grill and found it was left on and the tank was empty. It is irritating to change the tank but not a big deal. Different story if I come home to fi the stove and water heater out because the neighbor kids thinking it a funny prank to turn on the grill.
I rarely move the grill but it is nice that it is not tied down.
Walta
There are only two things
Mike L
on the house tank. A fireplace inside the house and a grill. The grill has a quick disconnect on it along with a shutoff.
Thanks for the reply's I decided to cook it in the oven this year until I can get the correct kit to connect it to the quick disconnect.
Happy Thanksgiving
Mike
