200+ woodworking book reviews
Further on Painting Kitchen Cabinet Doors
howgor
I've posted about this in the past and I am only now beginning to build the doors. This time it's for me but I want the result to be just as good if it were for one of my customers. I am going to use SW urethane based paint. Spraying paint for cabinet work is something I've not done before, but my commander in chief wants this paint. So here are the things I would appreciate help with -
1) If I brush it on, will adding Floetrol really make a big enough impact on making the surface look as if it were sprayed on?
2) In the past I had asked for spray rig recommendations but I don't remember what they were, would you mind stating them again. I would like to spend no more than $600-$750 if that will get me a good rig, which I guess would be an airless unit. I don't think it will get much use after this, so a reasonable set-up is what I am after.
3) Overall what are the thoughts on brush/roller versus using an airless sprayer?
Thanks, Howard
Re: Further on Painting Kitchen Cabinet Doors
Tom Norton
I am assuming you will brush the cabinetry and spray the doors and drawer fronts in a shop. I have done a number not spray jobs using a HVLP gravity feed gun from Home Depot. I use Benjamin Moore Advance. I believe this is similar to SW. Yes adding an additive will make a big difference. Invest in the best brushes you can.
I have sprayed acres of wood
Want a glass smooth surface?
Then: spray solvent based Kilz, sand 180, spray thinned oil paint, 2 coats.
I used a suction fed conventional spray gun, DeVilbiss or Binks, all the same, #30 cap. These guns are available used for as little as $50 but $100 would still be a good deal, Ebay or elsewhere. Any modest sized air compressor will run it, 30-40 psi.
I finish everything with this gun- lacquer, shellac, paint, conversion varnish, varnish.
