200+ woodworking book reviews
Drum/belt sander recommendations ??
AZ in Colorado Springs
We're looking to upgrade the big drum sander at the Air Force Academy hobby wood shop. The current machine is a 17" wide Powermatic (don't know the model number). It's at least 15 years old.
So, what would you recommend for a public use facility? The customers have a wide range of experience, from zero to very experienced wood workers.
We'd like something wide. The Powermatic that we have is a 17/34, but if you reverse the workpiece you get a gully in the middle. We're unable to get the platen and the drive conveyor parallel. We also need something durable, so inexperienced users don't easily knock it out of service.
Thanks
Re: Drum/belt sander recommendations ??
Clint Searl
Jet 22/44
I have a Performax 16/32 that i believe is the Genesis of the Jet machine. (Jet bought the machine form Performax.) The reason I mention it is my understanding is the drum is not supposed to be parallel to the bed. The drum should be higher on the open end, one or two hundredths of and inch to avoid the gully. That means all the pieces are very slightly tapered, but you can reverse them creating a very slight crown and then hand sand.
Supermax is the remnants of the Performax company and still make similar sanders. I would look at them and Jet.
As an Aside, I also have a Grizzly dual drum sander. I can change the sandpaper on my Performax in under five minutes and it works reliably. On the Grizzly, their own literature indicates it's a two man job and it pretty much is. Not easy to do it by yourself I work alone. I changed to the hook and loop version but its still a B9TCH.
E Phillip Smith
I have the Supermax 16/32 and it works well.
Not a drum sander!
Craig
I've had both the Performax 16/32 and 22/44 for years and I can't imagine how they could be used in a public shop unless you buy stock in the sandpaper company. I'm careful to take light passes on mine to prevent burning but that won't happen in a group environment. I'd look at one of the smaller open end 15" belt sanders instead. These machines are meant to be babied a bit to keep them working properly.
Agree with Craig 100%
Thanks
We'll look those machines up and see what we can do.😎
