Compound miter saw stand?
I need one. Don't want to spend too much money as I don't go to job sites - I just need it for my shop - and for redoing all the baseboards in my house.
It could have wheels (or not) - it would be used to hold my old DeWalt 12" CMS.
Re: Compound miter saw stand?
Jim Dillon
JL, I built a "portable" one from Shop Notes years ago. I will look up the reference Saturday as I am busy tomorrow. Will try to take some pictures also. It has worked very well over the years. More later. Jim
Paul Blackwell
My wife got me a stand to go with my 12" DeWalt CMS. The stand is also by DeWalt, but I don't know the price. the DeWalt stand is excellent.
I have the Rigid
Mike L
I bought the Rigid last year on Black Friday. They offered it at $100 for a few years now during Black Friday. I like the way it supports the saw and the extensions are easy to get in and out. I leave my saw on it all the time and park it against a wall for storage when not in use.
Jack Guzman from Maine
make one
I always wanted a good one but couldn't justify the expense so I built one. I used a 2"x12" for the table and built up the sides to support stock. I place it on sawhorses when outdoors or place it on a bench in the shop.
DeWalt
Lowes had the Dewalt aluminum stand on sale when I started the interior finishing work on my shop building. Mounted my Makita LS 1211 on a piece of 3/4 ply to attach.
Worked great saved much effort in handling lumber. Portable to take to the kids' houses when in demand ;) Beats the snot out of a couple of sawhorses!
$200 at Lowes although I got mine at $150.
Re: make one
John McGaw
That is probably the way I'd go again. I built mine along with the almost-identical router table on casters and at exactly the same height as my workbench and Robland combination machine so that, in a pinch, all of them could be used as extensions or work supports for each other. I settled on 34" as the proper height since that is what the Robland is and it is the one that couldn't be changed. The DeWalt miter saw sits on the stand restrained only by wooden pegs (it is heavy enough that bolting it down would be pointless -- gravity does quite well) and it can be removed in a minute. With the router table slipping the fence off does the job. In a shop in a one-car garage things can get very tight very quickly and wheels and storage are the thing.
JL. I have one still in the box. For the life of me I can't think what brand it is and I am out of position to go look at it at the moment. I will give it to you if it suits you and you pay the shipping. When I get home I will look at it and send details if you are interested.
Re: I have the Rigid
I also have the Ridgid, bought maybe 5 years ago to support a Bosch glide SCMS. It's excellent, especially if you need to move the saw on occasion.
AZ in Colorado Springs
I took an old gas grill and removed the fire box and the control panel. Used some plywood and 2x4s (as spacers) to make a table top same height as my table saw, so it could double as a narrow outfeed table. I got some sturdier wheels at harbor freight to replace the hollow plastic wheels.
When I got a DeWalt CMS, I mounted it on this table. Used plywood to make some blocks on either side to support the stock. I also have a workmate and I made a spacer that clamps to the work surface of the workmate to to be the right height to support long stock.
I lost my portable outfeed table, but I now have a 7' long roubo style bench that can serve that need. Very sturdy as an outfeed table.
Portability
Is a nice thing. I have a lower cabinet on my wall that I place the CMS on when it is in my shop - but I often use the CMS in my garage to "break down" the larger pieces of lumber before storing them in the rack in my shop (and soon to be the rack in my shed).
I also have a LOT of baseboards to do - so portability is an issue for that. I would prefer to do that nearer to where the baseboard will be installed.
Jason Roehl in Lafayette, IN
Re: Compound miter saw stand? *LINK*
I have one similar to the one linked below. The one in the link is newer, as I've had mine for probably 12-15 years, and it has some updates on it. Mine folds up and rolls with the saw on it, but it has to be held low to roll it. The wheels seem positioned to roll it around a little by lifting one end while fully set up. Also, I think at least one of the wheels is now broken (they are 5-spoke plastic and fairly thin). I don't use it much anymore because I haven't used that saw much in the last several years (no longer a contractor).
Jason
Menard's Miter Saw Stand
Jim Dillon
JL here are pics of two "stands" that I built 25 or so years ago. The first one is more portable that I used for cutting interior trim and exterior log siding. Those metal objects are joist fasteners. The 2x6 is 8 feet long but you could make it shorter to fit your needs.
Jim
PS I had a longer response but for some reason it would not post. Maybe this will work.
Jim Dillon
The stand I use in my shop is not really portable although it is on wheels and will roll around on a smooth concrete floor.
I built this stand when the only tools I had were a portable contractors saw, a biscuit joiner, and a router. The SCMS sits on a rather clever assembly that is portable (if you have a strong back). The extension wings detach and fit inside the box.
Bosch also makes a portable SCMS stand but I was surprised how expensive it is.
Jim
Bought the Ridgid
It was not inexpensive, but it should fit the bill.
Re: Bought the Ridgid
Jim Dillon
Great choice JL. I like the wide wheels. Keep us posted on how well it fits your needs. Jim
