Bandsaw Lubricant
Bandsaw Lubricant
Bandsaw Lubricant
Garthinsandiego
A couple of people have asked about bandsaw lubricant in another thread. Starting new thread rather than hijacking that one.
What I think others have referenced is sold as stick lubricant, not specifically limited to bandsaw use. It is a mixture of waxes, primarily paraffin contained in a cylindrical cartridge similar to automotive grease. I purchased mine from MSC.
The primary advantage is that it is tacky and therefore sticks to blades or abrasives better than plain paraffin or an old candle (colored and perfumed paraffin. ) It is convenient to use (just push the end of the stick into the blade) doesn't crumble, and lasts a long time.
Re: Bandsaw Lubricant
David Yoho
I know there are those that keep a toilet wax ring handy for lubricating screws. I just poke my screws into a can of Johnson's Paste Wax and drive them home. I also predrill hinge holes with a Vix bit and sometimes run a steel screw in before installing the brass screws. Don't need to lubricate them doing it that way.
Garthinsandiego
Do that too! The bowl wax is also handy to stick a screw to the screwdriver blade when your fingers can't easily support the screw. Hold nuts in wrench or socket, etc., etc.
Screw/Bandsaw Lubricant
the end of one of these sticks is shown in the PIC I posted on hinge installation. What may not be appreciated is how conveniently this stuff transfers from stick to screw thread. It is just the right viscosity and sticky. I tired all they other stuff. When I was given a few inches of this stuff it became all I use.
To clarify, it is used for metal cutting band saw blades.
