Bandsaw MM16
Don Evans
I tried to contact MiniMax about adjusting the footers on my MM16 due to an uneven concrete floor. I could not find them on the internet? Any of you with this type saw know there web address?
Don
Bandsaw MM16
Don Evans
Don
Re: Bandsaw MM16 *LINK*
John McGaw
It is not immediately obvious but MiniMax is made by SCM. If you go to their home page and then make use of their site search you might be able to get a bit closer to what you want. I did not dig too deeply.
SCM Home Page
Re: Bandsaw MM16
Doug Reynolds
There used to be a MiniMax users group. I’ve not been knit in awhile though.
Re: Bandsaw MM16
Don Evans
Thanks for you help guys, I previously checked out the SCM site and they don't even list any bandsaws on their site. I guess there wasn't enough interest in the USA. Other countries appear more interested.
I note they still have an office in Atlanta, GA I'll give them a call.
Don
Re: Bandsaw MM16
Doug Reynolds
I have a MiniMax 20 bandsaw which I like.
Discovered, I think, that Yahoo shut down all its Users Groups. Used to get good info from there.
Best of luck, Doug
Re: Bandsaw MM16 MANUAL
Don I have the MM-16 - great saw. I looked on the net and found this site with a copy of the user manual. Think it has the information you were looking for earlier.
file:///C:/Users/Larry/AppData/Local/Temp/MiniMax16M-1.pdf
Not going to work
David Yoho
Larry, the link you have references a file on a drive somewhere, not a webpage to view it. Try linking to the site or page you found it.
Re: Not going to work *LINK*
John McGaw
I did the search using the file name alone and came up with the following link which appears to be a valid result:
Ahh, the wonders of web search technology...
That's it
David Yoho
Turns out I had that PDF file on my computer already. Must have found it years ago when I got my saw and saved it.
Re: Sorry
I was going to correct the link then saw you already had done so, thanks for the help!
