dove tail 2x
Buckaroo
How do I set up & what/which bits to use for dovetailing 2x6 or 8 or ??
dove tail 2x
Buckaroo
Through dovetails or half blind?
Half blind it doesn't matter. Any reasonable bit would do - though I would choose a dovetail bit with a larger angle if you are doing pine or another soft wood.
The "longest" bit that I've seen is a 1" bit. I have heard of ones that are 2", but I haven't seen one and have no idea where you might find one.
Are you asking about framing lumber? *LINK*
Dick Coers
What is the actual board thickness, 1 1/2" or 2"? Keller sells 1 1/4" CL. So you can rabbet the end of the board and use a shorter bit. If you only have a few, cut them by hand. Otherwise it will be hundreds of dollars for a jig and bit. $469 for the Keller bit dovetail jig and bits.
https://kellerdovetail.com/models.html
