The Phantom 8th
So I've actually started (or restarted if you wish) woodworking in the new shop. I thought that everything was tuned to the proverbial "gnat's eyelash" [Ponders may remember] but when I went to employ my shop-made miter/cut-off sled I discovered that the cut line was 1/8" away from the blade. Hummmm
Pulled out the finger joint jig . . . also short of the blade by an 8th.
The cross-cut sled? Same-o.
This will NOT do.
I was sure the table saw had been set to factory spec so the only answer was that all of my jigs and stuff had shrunk by an 1/8" due to sitting idle for 6-8 months.
So, do I tear down the saw table, factory specs be damned, and re-set its parts to make the jigs fit?
Ahhhhh, no.
Make all new sleds and jigs to celebrate the new shop?
Nah.
Cut some 1/4" hardwood stock and glue it to the jigs' cut lines, then run them through the saw to get the new "0" line. Check the other parts, adjust where needed to true them up.
Done.
Happy Halloween!
