Mineral Spirits- 5 gallon pail question
Tom Norton
I will be getting a new pail of mineral spirits tomorrow. I buy it this way because I can get it first out $7 per gallon and it is a high quality. But I was wondering if anyone has a suggestion on a "valve/ spiget sp? for a 5 gallon pail?
Thanks!
Re: Mineral Spirits- 5 gallon pail question
Thomas Dunlap
You're looking for a 'bulkhead valve' I have some to sell cheap. Made of brass with hose fitting. Email for details.
Tom Norton
Being tech challenged I am not sure how to locate your e.
Plastic or steel pail?
I haven't tried them for anything but honey but I put "honey gate" valves in sides at the bottom of 5-gal plastic buckets for filling bottles. Also, the hardware store has a variety of valves that should be ok for steel or plastic pails.
I decant mineral spirits from 1-gal cans into smaller plastic bottles for use as needed.
Thomas Dunlap
canopytree@earthlink.net
5 gallon bucket pump
GolfSteve in Calgary
Putting a bulkhead fitting at the bottom of the pail might work, but the rubber seals might be incompatible with mineral spirits, and puts you at risk for leakage.
At work we use "5 gallon bucket pumps" that install in the lid of the pail. Cheap ones cost less than $20.
At work we have a lever action pump that works well and is available online for around $40.
...when looking up bucket pumps, Amazon advertised a siphon hand pump, which was a squeezable bulb with flexible tubing on each side. This would also work if you didn't need very much solvent, but would be much messier than the bucket p ump....
Re: 5 gallon bucket pump
Walter Ahlgrim
You may want to consider a pump like this one.
https://www.homedepot.com/p/TERA-PUMP-2-5-GPM-2AA-Battery-Powered-Fuel-Transfer-Pump-TRHA01/301665397
I got one from aliexpress they have very low prices if you can wait 30+ day for delivery
https://www.aliexpress.com/item/33007021855.html?
spm=a2g0o.productlist.0.0.3e4a21adbBNxT9&algo_pvid=8835ca5a-bba7-4eac-b680-7fdb4e48d75c&algo_expid=8835ca5a-bba7-4eac-b680-7fdb4e48d75c-0&btsid=6a968092-42b1-49b1-a3c5-3ee72ea41dd5&ws_ab_test=searchweb0_0,searchweb201602_5,searchweb201603_52
https://www.aliexpress.com/item/4000244797243.html?spm=a2g0o.productlist.0.0.3e4a21adbBNxT9&algo_pvid=8835ca5a-bba7-4eac-b680-7fdb4e48d75c&algo_expid=8835ca5a-bba7-4eac-b680-7fdb4e48d75c-6&btsid=6a968092-42b1-49b1-a3c5-3ee72ea41dd5&ws_ab_test=searchweb0_0,searchweb201602_5,searchweb201603_52
Walta
