Cherry T&G flooring
Cherry T&G flooring
Cherry T&G flooring
Mike L
A real WW topic from me(-; I have an opportunity to get some T&G Cherry hard wood flooring 3/4 inch thick. I am going to use it as a counter top on a cup board and a sort of bar top area. I know you use nails in the tongue for flooring. What I was wondering is if I could just glue it up into a panel clamp it then place it on the top of the cup board. To make it thicker in front I was thinking of ripping a piece and gluing it along the entire front. Or do I have to nail it like flooring to ribs across the cabinet?
I hope I am making sense.
Mike
Re: Cherry T&G flooring
Re: Cherry T&G counter top
You can glue it into a panel but you'll have to allow for movement for climate change. Your joints will collect spills etm so consider how you'll seal them. Will 3/4 stock, an apron is probably called for.
JohnV
Possibly glue the cherry to a piece stable ply or MDF 3/4" thick.
Put two or more pieces together and lay them on a flat surface and look at them from the end. I have found a lot of T&G flooring pieces are "eased" on the bottom side. That is, when the top surface is pulled up tight, the bottom edges will have a 1/32" or more space. Makes it easier to make the top tight without interference from the bottom side. Also makes it hard to make a self supporting panel as only the top shoulders will be glued.
Gluing solid wood to MDF or plywood
Dick Coers
Gluing 3/4" solid lumber to MDF or plywood is a really bad idea. When the wood shrinks or expands with the seasonal change, you will be a bow, or solid wood cracks. Something has to give when you lock it down!
Is it chamfered on the edges?
Dick Coers
That's going to be trouble on a bar top. The grooves will fill with water or food particles. Is the flooring prefinished? Hopefully that is alcohol resistant.
Garthinsandiego
I would rip off the tongues and grooves and glue as in normal panel construction. Don't see any problem with gluing a piece along the long grain side of the resulting panel.
Jim DeLaney, Austintown, Ohio
Others have mentioned the various drawbacks - chamfers, spillage, expansion/shrinkage, etc.
What I'd do is glue the flooring into a panel - using a waterproof glue like Titebond III - and treat it like a glued up tabletop. Fasten it to the bar from underneath, using slotted screw holes to allow for the movement. Maybe - depending on the original finish - scuff the finish a bit and apply a couple coats of Behlen's Rock Hard Tabletop Varnish to it.
it is not finished
Mike L
I have not seen it yet, but I do know it is not finished. They place I am getting from saws the logs dries them then cuts them into flooring or just straight boards. I was thinking I could save a lot of work by using the T&G as a glue line.
I will look at it closely to see if the bottom is curved out or it has chamfer edges.
Thanks
If I understand correctly, in essence you are going to make a table top and fasten the table top to something under it. A table top assembled from the flooring will be no different than conventional.
There is, however, a problem to solve. You must have equal access of air to both sides or it will seasonally cup. You can't lay it on a solid base with no air gap. Finish both sides equally. And in fastening, you will have to accommodate seasonal expansion and contraction.
Mike L
That is the trick. It will be a counter top. If it is in panel form I will just place it on top of the cabinets under it and fasten the corners only. I am thinking the 3/4 inch on top of the cabinets should be strong enough to support itself across a 30 inch wide by 4 or 5 foot length. It will be used on a side cabinet in a dining room and another piece in a small section of the kitchen with a coffee pot on it along with some other small appliance. Not really used for food prep of anything of the sort.
Thanks
Stiffness not an issue. Air access to both sides critical to success. Finish both sides to slow moisture changes.
If you don't know them, look up "table top fasteners". An abundance of these across the ends will help hold it flat and enable seasonal change, which will be considerable. This top will be easily flexible across its width. Easy to hold down so long as it can slide in the holders.
Clint Searl
Clint Searl
Glue it up as a panel and stick it to the substrate with silicone caulk/glue, which will move with any seasonal movement, leaving the panel flat.
