A home for my diamonds
I don't spend much (too little) time on shop accessories. My diamond sharpening plates lived in grocery bags, not handily I might add. With the arrival of freshly surfaced plates I was motivated to give them a home.
The plate is laid onto some scrap of wood. Strips of wood are glued around its border as seen in the 3rd to the right box half. A second scrap of wood is glued to the top (don't forget to remove the plate before adding the top >( ). When glue is cured saw it in half on band saw. If you forget to remove the plate saw in half very carefully with a hand saw) Oil the back of the plate to keep for rusting, drop it in the box half and seal the joint with something (I used E 6000). Done!
It is so simple I could find the time to do it. And it used up scraps way to valuable to burn(yet).
Re: A home for my diamonds
But
I don't see and dove tails! :D
Re: But
John McGaw
They're just cunningly concealed...
William Duffield
Yours is similar to what I did for my chrome polishing compound, except I took a short cut or two. I glued the horsebutt strop to the bottom board and glued the sides only to the top board, so I didn't need to saw it apart. That probably resulted in my wasting more time fiddling with the fitment of the side strips. I figure a horsebutt strop charged with chromium oxide is much harder to keep clean and easier to contaminate than a diamond plate or natural stone, so making a covered container for it is higher priority than my other sharpening media.
I made one improvement by gluing a strip of wood across the bottom a couple inches from the front end of the box, so I could clamp it in my shoulder vise to keep it from slipping around.
I used 0.3 micron dry Cr2O3 powder that I mixed with mineral oil. To apply it to the strop, I loaded the mixture into a syringe (Monoject 412), making a big mess in the process, squirted a little onto the strop, and spread it around with the first edge I honed on it.
