Photo canopy
Photo canopy
Photo canopy
Paul grover
Need a portable photo canopy to photo wood-turnings ,using a iPad. Would appreciate recommendations.thanks Paul
Re: Photo canopy
Re: Photo canopy
John McGaw
Simple enough to make using some wooden dowels, drafting vellum (or better yet Mylar if available), a roll of neutral photo backdrop paper. I made mine in an hour or two and used it for years before I moved and it went missing. In a pinch you could get along with just the background and a couple of large light sources such as diffused scoops or any source with a diffusing scrim. In a pinch I've even gotten by with window light and a reflector as the light sources.
I do have something called a "Merax One Shot Photo Studio" but find it a PITA to set up and use and too small for any object beyond the size of a 4-inch bowl. On top of that it is so shallow that trying to use a small aperture for decent depth of field the background comes out in focus, generally not what one wants.
Re: Photo canopy
Re: Photo canopy *LINK*
Jim Dillon
Paul, here is a link to DIY light box made from PVC pipe. I have no experience with building one, but bookmarked this web site long ago just-in-case. The amazing thing is that I was able to find the bookmark! Hope this helps. Jim
DIY Light Box
Re: Photo canopy
Re: Photo canopy
John McGaw
That looks pretty much like my wood dowel one and using fittings like that should make it easier to build as it avoids drilling a lot of accurate holes.
Re: Photo canopy
Re: Photo canopy
Jim Dillon
John, if one had a source for those fiberglass "wands" that are used to erect modern-day pop-up tents, the light box could be even more portable. I guess one would need some sort of corner connector to make the "box". Would be a fun project. Jim
Re: Photo canopy
Re: Photo canopy
Don Stephan
Using PVC and fittings, building the frame was a snap. Found photo diffusing fabric at a mail order photo business, or I was told parachute fabric also works. The issue was lighting - even stronger LED lights in clamp lights don't put a lot of light through the diffusion fabric, and without the fabric lots of reflected glare.
Re: Photo canopy
Re: Photo canopy
John McGaw
Fiberglass arrow blanks would work great but, as you wrote, the connectors would be the stumbling point. Of course if one owned a 3-D printer...
