Segmented Glueing Without Making a Mess
howgor
I make a lot of segmented bowls and pictures with many pieces glued together. Typically I use very thin laminate to glue on and try to wipe off the glue that gets on it, but usually there's enough build up that I have to throw it out. Gets costly to keep using these kinds of materials, wax paper gets messy. What methods do you folks use when needing to do a high volume of glue-ups??
Re: Segmented Glueing Without Making a Mess
Chuck Hans
Try putting a coat of Johnsons Paste was on your laminate and the glue will not stick to it. Works like a charm.
Re: Segmented Glueing Without Making a Mess *LINK*
Dick Coers
Cutting sheets. Should be flexible enough to just roll around when the glue is dry and it will pop right off.
https://www.amazon.com/Norpro-47-Jumbo-Flexible-Cutting/dp/B00004RIY8/ref=asc_df_B00004RIY8/?tag=hyprod-20&linkCode=df0&hvadid=198076847952&hvpos=1o1&hvnetw=g&hvrand=5342798197172033268&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1016
Thanks
Stuart Johnson
I like the silicone bakers mat: https://www.amazon.com/s?k=silicone+baking+mat&gclid=CjwKCAjwwvfrBRBIEiwA2nFiPUG3StdAKLLMVNZVFDtqB8L5hh7qGyhH_FBF2o_0pt9qwzTDIlk7qBoCj6cQAvD_BwE&hvadid=176938065737&hvdev=c&hvlocphy=1026726&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=17956302340454194967&hvtargid=kwd-98429595&hydadcr=13935_9624584&tag=googhydr-20&ref=pd_sl_2kinkyq8go_e
Ray Mtn. Home Ar.
I glue up on an old piece of laminate countertop, let the glue dry and scrape it off with a putty knife.
Woodie49
I glue up on Wax Paper. Have a Big roll of it!
Kneale Brownson
Xs2
Kneale Brownson
Re using scraper.
