ADVERTISE HERE - FREE TRIAL
Holly(wood) Follies
Holly(wood) Follies
Holly(wood) Follies
I occasionally cut trees for friends. Requirements are that both feet remain on the ground when the saw is cutting and nothing is in the target zone that won't grow back ;) Someone planted a full sized holly 3' from the house and never trimmed it to be the shrub it was intended to be. When it eclipsed the basement, 2 floors and the roof it was time to go.
It was not a desirable tree for lumber for it had numerous branches. But it was on the ground, there were a few clear sections and for stringing and inlay big pieces are not required. for example:
Holly dries easily but it is prone to growing mold which makes it blue or black and if it dries too slow there is something Wengert refers to as chemical stain that makes it gray. Ideally holly is cut in winter and dried cold to prevent mold from invading. This holly was oozing sap that mold was sure to favor.
The wood was free and an experiment was in order. The pieces were too small to bother the saw mill so I whacked them on the band saw. The goal is to get two orthogonal faces and then the billet can be cut to lumber. Screwing a straight edge on the log worked to get one face. Jointer, draw knife, and scrub plane got the other.
It made a mess.
We are in a hot dry spell. I coated the surfaces with fungicide and stacked the pieces in the sun. The combination of quick surface drying and fungicide might prevent mold from establishing; we shall see. So far the surface is mold-free.
I didn't have any Anchor Seal on hand. I will get end checking that could have been prevented.
Re: Holly(wood) Follies
Update
After a day of baking they are still white, actually a bit yellow from the oxidized surface, a good sign. And they have lost significant water. How much. Well that was a screw up. Always weigh a test piece to start and follow it.
Re: Update
Keith Newton
A quick drying may keep the surface dry, but the inside may turn gray. You might put a couple of pieces in your freezer until hog killing time unless you know someone with a vacuum kiln.
Years later
Gary Smyth
In my view this is the best project you ever made. As you favor close relatives with your projects I'm available for temporary adoption. Place me on the list for one spice cabinet please!
More updates
The wood is drying at a rate of 5% a day, shower than I thought it would for 90 degree days. The surface is staying dry, by experienced feel about 10-15% moisture content, way to low for mold to propagate. Remains to be seen if inside turns grey from "chemical staining".
When a friend cut holly in the spring it molded through in 24 hours. Sap had a high sugar content at that time. My tree was starting dormancy and the sugars have turned to starch for winter storage. To my surprise the slabs that are in a location where they are not drying much have not molded. So, time of year may be the most critical factor.
thank you for compliment
In fact the spice box is in storage for Granddaughter until she is 9- one more year. And the corner cupboard is also in storage until I can get it delivered (5 1/2 hr drive). Next on the list is a coffee table as soon as daughter completes the design.
Re: Corner Cupboard Photos?
Hank Knight
Bill, did you post photos of the finished corner cupboard? You fans want to see.
