OT- Plumbing
OT- Plumbing
OT- Plumbing
Tom Norton
My Reverse Osmosis system is here and now the installation begins!
As I am doing a remote location I bought a roll of 3/8" pex to run across the basement an up to the faucet location.
So I need a fitting that goes from 3/8" pex to 3/8" tubing.
Anyone familiar with these?
Thanks!
Re: OT- Plumbing
Re: OT- Plumbing
Dick Coers
You’ll probably have to go from pex to pipe thread, then tubing.
Re: OT- Plumbing
Re: OT- Plumbing
Tom Norton
Thanks!!
I was thinking that I might have to go to pipe thread then tubing. I was hoping for a fitting that would di both.
Time to spend time in the plumbing aisle at HD!
Re: OT- Plumbing
Re: OT- Plumbing
JohnV
SharkBite makes a connector for this. It is a push fit connector. I've used them for years. Most of the borgs carry them.
Re: OT- Plumbing
Re: OT- Plumbing
Stuart Johnson
The problem I ran into with SharkBit was trying to install an outside faucet. A copper pipe worked great but with SharkBite I had to secure the faucet to the wall because if would just spin in place.
Re: OT- Plumbing
SharkBite Tip
David Yoho
There is a SharkBite fitting for that. A professional plumber gave me a tip I've used with success. When using these fittings with PEX and other plastics take a pair of needle nose pliers and yank out the plastic sleeve in the end of the fittings. This prevents the pipe or tubing from misalignment and not seating fully. Removal has no affect on sealing.
Re: OT- Plumbing
Re: OT- Plumbing
walta
I think the tubing from the water filter is likely to be polyethylene tubing. How sure are we that SharkBite fittings are listed for use with polyethylene tubing? I could not find a mention of polyethylene on the SharkBite web site.
I think the best bet is to use polyethylene tubing for the run as long as the pipe will be exposed.
Walta
Re: OT- Plumbing
Re: OT- Plumbing
Tom Norton
That was my first thought but I needed a 100' roll and was having difficulty find anything other than 25's. So I thought about the PEX.
