Corner cupboard finish selection strategy
Pictured is the need. It has 3 surfaces that differ in their finishing requirements.
The outside show surface- It needs to look pretty and be durable in a dining room area. This thing is going to be used and a minimalist "museum finish" will not hold up. *** Stain, Waterlox varnish. I love its rich luster. I can't achieve it except by some varnishes and shellac.
Interior- A varnish interior risks smelling like old varnish, a result of oxidation of the oil to yield rancid smelling degradation products. ****Zinsser waxy shellac. It ages to yield a fruity ester odor in an enclosed space and it is durable enough on the vertical interior surfaces.
Shelves- Needs to be durable and not stink ***Target waterborne urethane finish. Crappy luster by comparison to the varnish by not an issue for a shelf with plates piled on it. The front edge of the shelf I will shellac.
Re: Corner cupboard finish selection strategy
Kneale Brownson
Looks great, sounds good.
Thanks for this. I clearly need to be
Chuck Nickerson
more thoughtful with my finishing schedule. I'm working on a china cabinet (16' l x 7'h x 2' d) with similar use requirements but would not have considered three finishes.
Re: Thanks for this. I clearly need to be
I'm trying to make this thing more complicated. :) Actually, it has become complicated enough as it is. And we haven't got to the designer or leaded glass part.
Actually, minimizing varnish is good. The others dry quick and I can recoat and be done in a day.
William Duffield
Sounds like a plan. It all makes sense to me, except I'm not familiar with waterborne urethanes. I assume you are spraying the shellac interior? We've always used Zinsser 3# Orange (probably the same, renamed, as what you are using) and rubbed it down with 0000 steel wool or grey ScotchBrite. We also apply the same to kitchen cabinet shelves and other shelves, but we have always assumed the dishes will be washed and dried before being put back in the cupboard (maybe not a valid assumption in the 21st Century.)
