apothecary cabinet *LINK*
McKay
This is a cabinet that I just finished. It is for the shop and other construction details are found at "woodworkers are never board". Thanks for looking.
http://woodheaven.blogspot.com/
McKay
Re: apothecary cabinet
Ron in Sterling, CT
Fantastic Build, and something to be very proud of. I would go nuts trying to keep 100 drawers straight.
Thanks for sharing.
Ron
Yonak
That's a fantastic looking piece, McKay. I can only dream . . What's it used for ? How do you slide out pie-shaped drawers ?
Well that's impressive. I would like some discussion of how it was built. It could win the award for most unusual furniture post of the year, or decade.
Build Description is in the Link
Ray Newman
Outstanding craftsmanship!
Colleagues: take the time to view the "build blog" in the link the original poster linked to as well as the older posts/projects on his blog and older blog entries.
I like it!
John in NM
Love this kind of cabinet, great work on an ambitious project!
Awesome
I can't imagine undertaking something so involved for myself. I can't imagine what I'd have to charge a paying customer for one of these. Thanks for the inspiration, McKay. It looks like you figured out the pic-posting drill, too.
Terrific Build!
You must be proud.
Jim Dillon
McKay, man that cabinet took a LOT of work, and patience! Your blog post is very instructive. WC viewers - make sure to click on the pictures in his blog post to see an enlarged view. Thanks for taking the time to post here. Your bio is very interesting as well. Jim
A cabinetry tour de force
Great job McKay, I hope you took some pics with *LINK*
Keith Newton
some of the drawers open. I did one similar about 10 years ago using figured Bubinga and Pear wood. Mine had 88 drawers, and was on a bearing base so it could spin.
I was wondering if you used any kind of stop for the drawers, or if they will come all the way out. Since mine would spin, I had to put a pin in the bottom of the space above each, which would keep them all from flying out if a kid came along and gave it a spin. I just used a 5mm shelf pin dipped in contact cement before reaching in inserting it into the hole with the drawer half open.
Here is a pic of mine, and several following with some of the drawers open.
https://www.flickr.com/photos/7391658@N03/9267190489/
Amazing work...
Brad Chenoweth
by both of you!
Keith, are the drawers in your cabinet captured somehow against the vertical dividers as they open? I'm trying to get my head around how you did that. Cool stuff!!!
Brad Chenoweth
how are the drawers built?
Re: Amazing work...
Keith Newton
All the drawers are made from QS Sycamore, so nice creamy white flake with finger joint corners. They are about 1/16” shorter in height than the opening.
It appears that MaKay built his cabinet with the vertical joined in the middle with the shelf dividers added in between, I took a different approach. I first cut a dozen octagonal shelves then dadoed in from the corners for the vertical sides which were also dadoed to to hold the shelves at the right height. Then that was all trimmed out with pear wood.
The pie shaped drawers fronts were veneered with the Bubinga using epoxy for the adhesive, with spring clamps pressing a 1/2” mdf caul and 1/8” packing foam between it and the veneer.
I think that the complexity of that chest is amazing. My own is only curved at the front, not all around.
But it does have hand dovetailed drawers (I could not imagine how these could be made any other way) ...
Re: Great job McKay, I hope you took some pics wit
McKay
Keith, after seeing your work I feel that I should take lessons from you.
Thanks but I don't know about that,
Keith Newton
Maybe we both ought to take a trip down under to work with Derek on a collaboration and see what we'd come up with if we all got our heads together. ;-)
