Table Halved
Table Halved
Kneale Brownson
Table Halved
Kneale Brownson
Just over a month ago I asked for suggestions on ways to get a bulky table into our new basement (http://www.woodcentral.com/woodworking/forum/messages.pl/page/9/md/read/id/525842/sbj/cut-paste/)
Cut the top in half today, turned it upside down on saw horses, inserted a piece of 2X4 between the side aprons on each side of the cut and completed the halving with cuts through the aprons. Now it's sitting on saw horses at the cut ends. I need to dress the cuts up some, clamp it together and provide holes for bolts to hold it together in the basement.
Do you think I'll need a removable fifth or sixth leg in the middle? It's used for laying out and cutting fabrics. It's about 4X7 feet.
Re: Table Halved
Re: Table Halved
Keith Newton
You might just screw a couple of 2x 4 cleats underneath that bridge the span easier than adding a leg.
Re: Table Halved
Kneale Brownson
Re: Table Halved; legs added
Kneale Brownson
Found that clamping the two crosspieces together did not keep the table flat, so I'm adding removable legs to the bolts that will hold the two crosspieces together.
