FWW Galbert Stool
FWW Galbert Stool
FWW Galbert Stool
Steven Kirincich
Hello,
Is anyone out there considering or actively building the curved-leg stool described in a Fine Woodworking article by Pater Galbert? I have been working on gluing up some clear 2 inch pine boards for the seat and also assembling the bending jig. The 1/2 inch felt just arrived a few days ago.
Re: FWW Galbert Stool
Jack Guzman from Maine
I am
I decided to build mine with green oak legs. Mainly because I have plenty of straight grained green red oak. I turned the legs and am drying the tenons prior to bending.
Re: I am
Steven Kirincich
Did you buy the plans from Peter? My lathe bed is about 4 inches too short to turn the legs, and I am thinking about the best way to provide an extension.
Re: I am
I did buy the plans from Peter. You could make the legs without a lathe. Start with a square and dimension all four sides with a drawknife. Then remove the corners to create an octagon. Finish with a spokeshave.
Re: I am
Steven Kirincich
Hi Jack,
I think that is very good advice since a lathe modification should not hold up progress. I saw the different leg types included in his plans. I may have to go to the local firewood guy and look at some oak logs. Thanks for your thoughts!
Steve
