BLO
BLO
BLO
Bruce, a MN Galoot
Does BLO have a shelf life? I ran across a partially used can of the stuff with a tag on it indicating that it would be about 25 years old. Before I use it on something important, it would be good to know if it’s still good.
Re: BLO
Re: BLO
I don't know what might happen to the catalyst. The oil is good forever. It gets thicker in time as it polymerizes but that thickening is not a problem. If too thick, thin. You could see if it still cures by putting some on glass and seeing if it gets as hard as BLO gets, which isn't very hard.
Re: BLO
Re: BLO
Bruce, a MN Galoot
I would just be using it to pop the grain, so thin is okay.
Thanks, Bill.
Re: BLO
Re: BLO
John in NM
I have a can from the 1960's that was in the garage of the house my parents bought 15 years ago. It's still good and a bit thicker is better in my view of things.
Re: BLO
Re: BLO
Ron in Sterling, CT
I have a can from the 1970's. It is a little thick and takes forever to dry. Every fall I take a small amount, thin it a some, then apply a thin coat to the wooden handles on all of my outdoor tools (shovels, spades, forks, etc.). After a few hours I wipe off any excess. By spring it is nice and cured and ready for another season. I have a can of "good stuff" for use in my shop.
Ron
Re: BLO
Clint Searl
Still good for incendiary accelerant
Re: BLO
What is top coat
catalyst in oil based varnish will cure linseed oil. But then if you are using varnish there is no benefit to using the oil.
Re: BLO
how to know when it is cured
smell. if it stinks like oil it is still curing and making those smelly low molecular weight compounds from the reaction with oxygen.
Re: BLO
What's the solvent to thin BLO?
Re: BLO
mineral spirits, naptha, or turpentine
I am skeptical that there is any difference in penetration thinned or not thinned.
Re: BLO
Thank you
Re: BLO
Re: mineral spirits, naptha, or turpentine
John in NM
I think there is a difference. I've cut up military surplus gunstocks and found that thin parts were soaked through with oil and assumed it was thinned drastically by the contractor who supplied the parts. Not sure if it was BLO though, so perhaps type of oil had more to do with penetration than did thinning.
Re: BLO
context
the task was to enhance grain. Don't need to penetrate inches to accomplish this task. I think the oil viscosity is irrelevant for this task. Data to support my hypothesis. Oil based varnish vs oil followed by oil based varnish looks the same.
That oil in my vintage ROTC rifle wood was assuredly not linseed. And yes it looked like it has soaked through and through.
Re: BLO
Re: context
Many old military arms were finished with "Tung oil". It is reportedly more moisture resistant than Linseed oil. It is also supposed to have a more transparent, harder finish. I have a couple of Garands - one from CMP with a new stock, finished with I'm sure is BLO. The older one I acquired appears to have a harder finish possible Tung oil.
Many countries started with Tung oil when a war broke out but switched to BLO as supplies of Tung oil was limited.
