A55 Smoothing Plane
Novel construction leads to novel clamping
I was suspecting the difficulties I was having building a corner cupboard were the result of not knowing how to build one. The day in the Headley shop confirmed this fact. But I press onward.
Conventionally the top, bottom and shelving hold the cupboard together. In my case daughter wanted adjustable shelving, and I built the front mitered vertical framing first instead of last. For the rest of the project I suffer these decisions.
What is most critical is a square frame for the doors. To that end I glued up the front door frames. But, there is little that holds them together at that point. I temporarily added a strip along the bottom(white piece of poplar in PIC) and a piece of plywood where the doors will go to hold the frame square until the face frame glue cured and this assembly glued to the case top and bottom.
One of the joys of building this thing is that there is nothing orthogonal to clamp to. This obstacle was overcome with the arrangement shown. Once I install the case sides it will become rigid.
A trammel is positioned across a diagonal in the door opening. The trammel is how I determine if something is square; use the trammel to measure diagonals. In this case they matched to within 1/16"- success!
Re: Novel construction leads to novel clamping
Joe in a Cleveland suburb
Glad to see an update on this project.
AZ in Colorado Springs
Are those bar clamps the Dubuque clamps that have been discussed recently?
Dubuque clamps -clear preference
I know them at "Universal Clamps" from the name of the company that developed them. I recently borrowed some Bessey's because I needed a long reach for a special situation. I found them heavy, cumbersome, and the adjusting screw was shorter range. I found noting to like about them other than for this application I needed a tall jaw. In that regard they are dandy.
The light weight nimbleness of the Dubuque clamps makes them a clear winner wherever they can be used. I can grab 3 off the clamp rack with one hand and have them positioned with little fuss. Their light weight doesn't weigh down the project like I am clamping and distort it.
Re: Dubuque clamps -clear preference
On Bill's recommendation I bought a dozen Dubuque clamps. I can't agree with him more. I appreciate them every time I use them. Get some, you won't regret it. Except you will want more.
