Identification please
Gary Smyth
Looking to identify.
I thought it was an (old fashioned “T” handle) explosive initiator (still might be for explosives). Size : Approximately 8”high x 7” x 7”. Hand crank on right side that is connected to a gear inside that is, in turn, connected in some fashion to the terminals on top. The screw terminals handle bare 14Ga wire in turn attached to alligator clips on 6 ft of wire at the other end. When the hand crank is turned, half dome bells ring loudly from inside the box. Box is fastened by eight screws on front and back. I haven’t touched them yet. Nor have I experimented touching both terminals at the same time with a meter or to judge the jolt. But with the resistance of the turning crank I don’t want to! There are two 50 cent coin sized vents/sound(?) on the front.
There is no release button to discharge – which is why I lost confidence as a blast box, but a on/off switch could be placed as a jumper on both terminals with the switch to complete a circuit.
Only other suggestion was as a power supply for a radio or telephone.
Suggestions?
