Deep exterior door frame assistance needed
Tom Norton
I have an upcoming project I have had in the back of my mind for sometime. I will be building a new front door for our home. I have built a number of doors in the past so there are no questions there.
My exterior wall is 11.5" thick. I want the door flush with the interior. Currently I have a prehung unit that is set to the exterior so it only comes "in" part way. I want to remedy this.
The challenge is,as I see it, is the threshold. I want to use white oak. But factoring bin the slope, approximately 10°, and the exterior protrusion. I am thinking it would be roughly 13.5"-14" wide. So I am concerned about movement. This will be a northern exposure.
Would appreciate your advice.
Re: Deep exterior door frame assistance needed
Keith Newton
If you are planning to use a single plank, I’d be sure to use QS, which should cut the seasonal movement in half of what plain sawn would be.
Beyond that, I would saturate it with a penetrating epoxy. It might not have have as much effect as it would on a softer wood but it couldn’t hurt.
If you can’t find any wide QS locally, get back to me, I’m pretty sure I have what you need
Is there enough height to do it in two layers - a base layer that makes up some of the width, with another, narrower layer on top, both shaped to make a walkable threshold?
Tom Norton
That idea gas been running through my mind. One concern would be the transition and it creating a trip hazard.
I have actually done this on 2 other doors but they have the aluminum thresholds that taper down to just 1/4" or so. I am not sure about doing that with white oak.
Kneale Brownson
What about a threshold seal?
