computer question-defaults
Periodically the computer, for no apparent reason, changes defaults. For example, WoodCentral, and some other sites now come up minimized where last week they came up full screen. Can defaults be user set, or are they controlled randomly by some elf on the Microsoft staff?
Re: computer question-defaults
Jack Guzman from Maine
I vote for elves
BrianFromMonumentCO
Most likely it was that you had used the control + to magnify the site once and closed your browser. Then it would start at normal little ittybity fonts.
By the way there are no elves at microsloth. Think trolls.
Mark Nowicki
IIRC you watched a video recently on Youtube. It might have set a cookie and changed your display settings.
I get that frequently, to go back to default I clear all browsing data,
Cntrl + Shift + Del in Chrome.
clarification and more data
I cleared cookies and everything and issue persists. To clarify, for some missed the problem......screens come up "minimized" instead of full screen as before. Extra step now to get full screen.
If I delete desktop short cut and log in from Explorer, then go to Messages, the site comes up full screen. I then create a new short cut and pin to desktop. Log out. Click short cut....comes up minimized.
Re: clarification and more data
mark nowicki
Which windows, 10 or 7 ?
Try This...
David Yoho
I had the same issue with internet shortcuts I placed on my desktop. This is what worked for me to make all open maximized -
Try this procedure...
Open a webpage link from your desktop. Stretch it out to fullsize. Don't use maximize.
Choose any link on that webpage and right-click> open in a new window.
Stretch that second window out to the desired size- don't use maximize.
Close the first IE window. Then close that second resized window. Now any desktop internet shortcut should open maximized.
Occasionally if you close a smaller window, you will have to do the process again.
